Which Clutch
Old Apr 18, 2006 | 02:19 PM
Fatty_1775's Avatar
Default Which Clutch
What would be a good clutch for a daily driver? B16, 9psi tuned 300 or so hp. Thanks.
Old Apr 18, 2006 | 02:38 PM
SOHC_MShue's Avatar
Default Re: Which Clutch (Fatty_1775)
ACT xtss
Old Apr 18, 2006 | 02:44 PM
StolenTeg's Avatar
Default Re: Which Clutch (SOHC_MShue)
Clutchmaster stage 3
Old Apr 18, 2006 | 03:39 PM
Fatty_1775's Avatar
Default Re: Which Clutch (StolenTeg)
no one ever mentions exedy? are those not good?
Old Apr 18, 2006 | 04:29 PM
b18sihatch's Avatar
definitly stage 3 clutch masters carbon kevlar, slips in smoothly, but grabs like a puck clutch, the carbon kevlar is very easy on the flywheel and pressure plate, doesnt eat the flywheel or pressure plate like the puck clutches, im not saying the exedy is bad, but their high end clutches are good, but their lower end clutch IMO arent as good as the clutchmsters stage 3 or the xtss is good for boost but i have read alot of people complaim of slipage with the hdss on boost
Old Apr 19, 2006 | 06:53 AM
b18sihatch's Avatar
what clutch choices are you looking at? i defintly recomend clutchmasters,act,RPS. it depends on how much you warrlet will let you go. a good stage 3 clutch that will be good for your setup new will be anywhere between 400-600.00. somthing smooth on the engaugement for everyday driving, but grab grab grab for boost, that is your goal. but what clutches did you have in mind anyway?
Old Apr 19, 2006 | 07:52 AM
RogueWorks's Avatar
Default Re: Which Clutch (b18sihatch)
Exedy stage 2 would work great for the torque you'll have in a 300hp B16, much better streetability for a daily driver.
Old Apr 19, 2006 | 07:55 AM
Schister66's Avatar
Man U FTW
i have the Exedy Stage 2 w/ a lightened flywheel in my GSR and after it breaks in a little bit, you can't tell its a pucked clutch....the pedal pressure is more than stock, but after a month or two, you dont hardly notice a difference in driveability.....
I would HIGHLY recommend it
Rhymenoceros
16
Apr 21, 2007 06:42 AM
MR. BAR
May 17, 2005 08:42 PM
Black DC2
Jun 3, 2004 06:09 PM
SubieDude
Oct 22, 2002 07:23 PM
proton
Jan 9, 2002 03:02 PM
