Closed Loop
Old Nov 21, 2002 | 04:54 AM
7rrivera7's Avatar
Default Closed Loop
Can someone explain the difference between closed and open-loop mode on an ECU?
Old Nov 21, 2002 | 05:53 AM
ekb18c's Avatar
Default Re: Closed Loop (7rrivera7)
closed loop= use of 02 sensor
02 sensor will make adjustments.
Open loop= not using 02 sensor
Whatever your maps dictates.
Old Nov 21, 2002 | 07:47 AM
racerxadam's Avatar
Default Re: Closed Loop (ekb18c)
and the ecu alternates between the two according to throttle postition, load, and engine temp to get the best fuel mileage and driveability. It might look at more sensors than that to decide but I'm sure it looks at TPS, MAP, and coolant temp.
Old Nov 21, 2002 | 09:43 AM
Vanilla Ic3's Avatar
Default Re: Closed Loop (racerxadam)
The way I understand things, closed loop is mostly for partial throttle cruising, and open loop mode is always used when you are wide open.
Carbcivic
11
Oct 11, 2007 05:45 PM
DanishR
May 14, 2005 11:05 AM
Zekueterna
Jan 2, 2005 11:34 AM
mrx
Mar 6, 2004 09:09 AM
