clocking/rotating t3 turbo HELP!
Old Feb 15, 2005 | 08:24 PM
dturbo's Avatar
Default clocking/rotating t3 turbo HELP!
I'm trying to clock or rotate the turbo so that the oil feed and drain is in the correct location. I loosened the bolts(which I think is the right ones)...took a hammer and hammered it pretty hard and still wont budge a bit? anyone run into this problem? or am i doing something wrong? It's a Garrett Airesearch T3 turbo...please help me out! I dont wanna waste this turbo....
Modified by flyazzcivic at 9:46 PM 2/15/2005
Old Feb 16, 2005 | 07:19 AM
PrettyLude's Avatar
just keep on tapping it and trying to move it, it will eventually move
Old Feb 16, 2005 | 02:26 PM
dturbo's Avatar
Default Re: clocking/rotating t3 turbo HELP! (slow poke)
I'm smashing the life out of the turbo...any other ideas on how to loosen it up?
Old Feb 16, 2005 | 02:29 PM
DaZman69's Avatar
Default Re: clocking/rotating t3 turbo HELP! (flyazzcivic)
try heating it up
Old Feb 16, 2005 | 03:12 PM
hondaguyef's Avatar
Default Re: clocking/rotating t3 turbo HELP! (DaZman69)
Try soaking it in some penetrating fluid and letting it sit.You can then try (where the oil inlet/return are) putting a small pry bar in and pring it apart. Be careful. Good luck.
Phil
Old Feb 16, 2005 | 03:34 PM
civicross's Avatar
Default Re: clocking/rotating t3 turbo HELP! (hondaguyef)
Old Feb 16, 2005 | 05:19 PM
dturbo's Avatar
Thanks for the HELP! I got it out! Was a pain in the butt but I got it...thanks!
Old Feb 16, 2005 | 05:45 PM
civicross's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
What? I dont possibly see how this pic helps?
What am I missing?
Put a wrench on that, and turn the CHRA to break it free.
fastcivicboy
Feb 9, 2006 09:22 PM
integracivic94
Aug 1, 2004 05:52 AM
Project_SOHC_EX
May 5, 2003 01:46 PM
