Chipped P28 in D16y8 > code 22 won't start
Old Jul 19, 2005 | 06:51 PM
flood's Avatar
Default Chipped P28 in D16y8 > code 22 won't start
Hey all,
just got a chipped P28. Put it in the car and it got a CEL 22 VTEC pressure valve. The old harness still has the VAFCII hooked up and I think this may be causing a problem but not sure. Any ideas?
98 Civic EX
Old Jul 20, 2005 | 06:19 AM
flood's Avatar
Default Re: Chipped P28 in D16y8 > code 22 won't start (flood)
Found out it was the VAFC wire that had come disconnected. Kinda figured it so.
New problem though, too much fuel. The spark plugs are wet there is sooo much fuel.
Old Jul 20, 2005 | 07:13 AM
ginoboy1978's Avatar
Did you get the ecu tuned? Or you running on a basemap?
Basemaps are usually made so the car runs really rich, so if its just a basemap.....get your car tuned.
DAN
Old Jul 20, 2005 | 08:16 AM
flood's Avatar
Default Re: Chipped P28 in D16y8 > code 22 won't start (ginoboy1978)
its a custom basemap made by MTBER and we have started to email back and forth about it.
Thing is I expect a basemap to run rich, but it doesn't run yet at all. Once it does get going I contacted Mind-Eracer from pgmfi.org and he said he could help out with the tuning. But its going to be hard to get it over there without it running.
I did get a Rom burner (burn1) and an extra chip so maybe If I get the bin file I can use the fuel mutiplier and knock down the fuel some more.
Old Jul 20, 2005 | 04:11 PM
Laserjock's Avatar
I ran into the same problem with my basemaps. I was running a walbro 255 and RC 450's and the car would not idle at all. Found out the stock FP was being overrun. Installed B&M AFPR and allowed my Y7 to idle (a little high but it idles now w/o shutting off) Cheap too. Got it from GSCMotorsports.com and the FP gauge from alchemist.
evreybody kept telling me "It's a basemap, it won't idle well. "Well, it wouldn't even run at all [roll-eyes]
If you unplug your electrical connector to the fuel pump and crank the engine a couple of times at it finally idles, you'll know you will need an adjustable FPR.
Old Jul 20, 2005 | 04:42 PM
mtber's Avatar
Default Re: Chipped P28 in D16y8 > code 22 won't start (Laserjock)
Britton,
I am glad to see that you figured out the code 22 issue was with your vafc wiring.
I hope the new bins I sent ya help you out :-)
If you don't have a fuel pressure guage & you are running the walbro 255lph HIGH PRESSURE fuel pump, your fuel pressure maybe sky high hence part of the issue you are seeing.
Anyways, feel free to contact me with any questions you have.
Thanks,
John Vega - Phearable.net
Old Jul 20, 2005 | 05:06 PM
dornon13's Avatar
i think the same happend to me...i have mysterious holes in my dash to the left of the cluster looks like a tach or something (vafc) was there... and i found qwerky wiring by the ecu with wires spliced into the vtec related wires and a few others....
what wires are used when wiring a vafc?
adrian_crx
Engine Management and Tuning
Aug 24, 2017 11:18 AM
teggsr925
Apr 5, 2010 04:39 PM
B18C_EH3
Sep 9, 2006 06:13 PM
B18C1 Civic EG
Jul 31, 2004 12:06 AM
