chipped ecu on nitrous?
Old Jan 11, 2005 | 03:57 PM
B16Civic93's Avatar
Default chipped ecu on nitrous?
why isnt it good to run a chipped ecu with nitrous? i have a chipped p28 for my b16 swap, i'm not sure what program, i bought the car with the swap. i've read that the chip advances timing. the thing is if i take the chip out wouldnt i get a cel and the car run like crap. especially since it probably eliminated the knock sensor. let me know
Old Jan 11, 2005 | 04:05 PM
93turbo16's Avatar
if you take the chip out and cut the jumper on J1 it will run the stock program on the ecu. It is not advisable to run a N/A program on nitrous for the timing reason. You could pull it on the distributor. I think that hondata has a nitrous control on it, I am not 100 percent about that, because I don't tune hondata. But depending on what ecu you have, it won't throw the knock sensor. If the ecu matches your car b16=p30 b18c1=p72 b18b=p72 d16z6=p28 you will have no problem just cutting the jumper and taking out the chip and running the stock map.
fatpride111
Sep 13, 2007 02:56 PM
teefunk01
Sep 6, 2005 05:26 PM
Griff
Aug 1, 2004 03:46 PM
dvp95
Aug 20, 2003 05:31 AM
KCDelSol
May 11, 2003 06:40 PM
