Check this out, need advice..
Old Dec 14, 2001 | 08:18 AM
VTC_CiViC's Avatar
Default Check this out, need advice..
Here are some shots of my plugs as they are now, I was hoping somebody could give me a little insight on them, make sure you see what I see (forgive the quality please!)
These are my newer BCPR7E-11's. I've noticed that since I switched from the 6 series to the 7's, my plugs never "looked" the same as before. I recall my old BCPR6's being darker, but maybe it was because I had them in there for like 15k miles? These are dark around the unsulator, the electrode is a dark grey, but the upper electrode/arc has a light tip with what looks like very small speckels.. any idea? BTW my fuel setup is:
RC 440cc injectors
V-AFC with about -15% trim at WOT for 10psi
93 octane pump gas
-3 degrees timing retard
stock igntion w/ new factory wires
Thanks
[Modified by VTC_CiViC, 12:19 PM 12/14/2001]
Old Dec 14, 2001 | 01:19 PM
quick108's Avatar
Default Re: Check this out, need advice.. (VTC_CiViC)
If those are dry sooty carbon deposits, you're probably running a little rich. The only other thing it could be is ash deposits, usually caused by fuel additives aka: octane booster.
But I think they look like normal boosted plugs.
Old Dec 15, 2001 | 08:28 AM
VTC_CiViC's Avatar
Default Re: Check this out, need advice.. (quick108)
Haven't used any octane booster (untill last night) so that can't be it.. anybody else have a take on this?
Old Dec 15, 2001 | 08:33 AM
Prelussion's Avatar
I've heard the little specs can be from Detonation, could someone please further speculate on this?
Old Dec 15, 2001 | 08:53 AM
jinxproof99's Avatar
New User
you look alittle rich if anything.
Old Dec 15, 2001 | 01:12 PM
VTC_CiViC's Avatar
Default Re: Check this out, need advice.. (jinxproof99)
Looks a little rich jinx? Hmm interesting.. thanks..
Old Dec 15, 2001 | 01:17 PM
New User
its a decent picture but its still hard to make out. if your lean, you'll have what looks like crystals formed which are very different from what it looks in the picture. if anything, your safe......at least thats what it looks like.
mildly.interesting
Oct 27, 2004 04:40 PM
4drNrunnin
Oct 11, 2004 11:24 PM
98lude-t
Mar 28, 2004 08:14 PM
greyzone
Dec 15, 2001 08:25 PM
