Check out my compression numbers!!!
Old Apr 5, 2005 | 10:56 PM
Boost Addict's Avatar
Default Check out my compression numbers!!!
#1 - 170
#2 - 177
#3 - 170
#4 - 178
How do these look? This is an H22 with 65k on it running 9 psi. I did a compression test because my tune sucks and it was dentonating and I wanted to make sure I didn't crack a ringland. Look ok?
It was done on a cold engine at WOT with the injectors still pluged in.
Modified by Boost Addict at 12:14 AM 4/6/2005
Old Apr 6, 2005 | 01:17 AM
s2kdre's Avatar
Default Re: Check out my compression numbers!!! (Boost Addict)
you can have bad ringlands and good compression numbers, so dont go by the numbers, just check for blow by.
Old Apr 6, 2005 | 05:50 AM
Benjithx's Avatar
Default Re: Check out my compression numbers!!! (jdmhonda)
if this was Carb Conns tune then plan on popping for some new slugs
Old Apr 6, 2005 | 07:08 AM
Default Re: Check out my compression numbers!!! (Benjithx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx &raquo;</TD></TR><TR><TD CLASS="quote">if this was Carb Conns tune then plan on popping for some new slugs </TD></TR></TABLE>
huh?
Old Apr 6, 2005 | 07:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote"> just check for blow by.</TD></TR></TABLE>
I did a search and can't find anything. Anyone know how I can check for blow by?
Old Apr 6, 2005 | 07:30 AM
DaveF's Avatar
leak down.
Old Apr 6, 2005 | 08:30 AM
adseguy's Avatar
Default Re: Check out my compression numbers!!! (Dturbocivic)
or oil comin out of your breather filter. If you run a catch can and have a lot of oil that is also blow by
Old Apr 6, 2005 | 10:29 AM
Default Re: Check out my compression numbers!!! (adseguy)
Can anyone tell me how the compression #'s look?
Old Apr 6, 2005 | 10:40 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Addict &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone tell me how the compression #'s look?</TD></TR></TABLE>
low. the static compression on an h22 is over 10:1, so im assumming normal compression #'s would be above 200. they are relatively consistant which is good though
Old Apr 6, 2005 | 10:49 AM
Default Re: Check out my compression numbers!!! (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">
low. the static compression on an h22 is over 10:1, so im assumming normal compression #'s would be above 200. they are relatively consistant which is good though</TD></TR></TABLE>
Most H22s I've seen have put out more like 220 on compression tests. I'm thinking mine may be low because it was done on a cold engine....
Old Apr 6, 2005 | 10:54 AM
adictionbass's Avatar
do it on a warm engine at WOT
Old Apr 6, 2005 | 10:55 AM
b20izzle's Avatar
whats he mean by that?!?!?
Old Apr 6, 2005 | 10:57 AM
Default Re: Check out my compression numbers!!! (b20izzle)
i think hes saying that Carb Conns does bad tunning and now he needs new pistons
VR4ownzU
Aug 11, 2007 11:12 AM
dbiker207
Nov 26, 2006 07:10 AM
pnoi_01dc2r
Aug 1, 2005 03:18 PM
japspec
Sep 28, 2004 02:42 PM
DOHCarp
Sep 11, 2003 07:10 PM
