Check out this intercooler!
Old Jan 6, 2004 | 03:54 PM
VNTEC's Avatar
B A N N E D
Default Check out this intercooler!
Its off a 99 Saab, the dimensions are 32 by 7 by 3. 2 1/4 end tank pipes
They are very simular to the dimensions of the Johnnyracecar.com intercoolers and they are actually thicker, what do u guys think?
Old Jan 6, 2004 | 07:24 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Check out this intercooler! (VNTEC)
Looks ok...but remember on Hondas...there is the "radiator support" that is in the way of the inlet/outlet for that used SAAB intercooler....Don't waste your time...get a FMIC w/ side endtanks instead!!!!
Old Jan 6, 2004 | 07:26 PM
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC &raquo;</TD></TR><TR><TD CLASS="quote">Its off a 99 Saab, the dimensions are 32 by 7 by 3. 2 1/4 end tank pipes
They are very simular to the dimensions of the Johnnyracecar.com intercoolers and they are actually thicker, what do u guys think?</TD></TR></TABLE>
THICK is not allwasy the best, The first 1/4 in thickness of the cooler does about 90% of the cooling. Just beacuse its thickier, doesnt mean that its better.
Rob
Old Jan 6, 2004 | 08:28 PM
VNTEC's Avatar
B A N N E D
Default Re: Check out this intercooler! (rjardy)
Cool, j/w because the johnnyracecar sizes are simular. The auction ended at 100 bucks on ebay, seems like a good deal. Btw, if i actually woulda got them, i wouldnt use those end tanks anyway!
Old Jan 6, 2004 | 08:59 PM
Copy Cat's Avatar
i think there is a guy on here who changed the end tanks, and had mad success with that intercooler. I think the person had a red si or something.
Old Jan 6, 2004 | 09:03 PM
baphomet's Avatar
Default Re: Check out this intercooler! (Ridinlowcivic)
kinda looks like a viggan inter-cooler, they can be had for 160 new. The end tanks are plastic but work fine. And if you search there was a guy that modified the end tanks a bit to point then side ways.
Old Jan 6, 2004 | 09:25 PM
ScrapinSi's Avatar
You rang??
I run it... works great... I plan on upgrading, but bang for the buck I give it
Test fitting the i/c before turbo install..
I will tell you this... It took ALOT of work for this to come out right... the way i set this up with the 90 degree bends out the back of the intercooler instead of their traditional "back door" design took some time and patience... I used 90 degree PVC bends. And you have to cut the bumper ALOT for it to fit.
If I were to do it over again, I would leave the back doors on it, trim the radiator support as needed, ditch the a/c, and run an ITR Charge pipe with a custom Back door lower i/c pipe to the turbo. I ended up ditchign the a/c anyways... just because i dont care anymore... LOL
Old Jan 7, 2004 | 06:29 AM
legendboy's Avatar
Default Re: Check out this intercooler! (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">Looks ok...but remember on Hondas...there is the "radiator support" that is in the way of the inlet/outlet for that used SAAB intercooler....Don't waste your time...get a FMIC w/ side endtanks instead!!!!</TD></TR></TABLE>
you should be able to move the "half rad" over a bit to make room for the inlet on the left side. I put a 944 intercooler in an eg with a half rad. Work perfect.
Race Egr
Welding / Fabrication
48
Jul 29, 2014 09:01 AM
Shmaa
Jan 26, 2006 07:56 PM
HiAssHell
Nov 17, 2005 10:24 AM
Perception
Apr 15, 2004 09:19 AM
Spade
Apr 4, 2004 12:04 AM
