Check my oil return
Old Dec 14, 2004 | 12:25 PM
nonvtecD's Avatar
Default Check my oil return
My car was smoking, after replacing the oil return and getting a restrictor I decided my turbo's seals were bad. Replaced the center cartridge yesterday. Put a new Steel braided return line on. My battery is dead so I haven't been able to start it up. Does my return look ok though?
I'm worried it is cocked forward too much but don't want to have to take the turbo off and clock it again, because it's 22 degrees out and a bitch, let me know what you think.
Old Dec 14, 2004 | 12:51 PM
Stewie's Avatar
Default Re: Check my oil return (D15B7turbo)
it looks like you can make the line a bit shorter
Old Dec 14, 2004 | 12:57 PM
f22b2tdave's Avatar
Default Re: Check my oil return (Stewie)
yeah from that last pic it almost seems to have a slight incline at the bottom.
Old Dec 14, 2004 | 01:00 PM
adseguy's Avatar
Default Re: Check my oil return (f22b2tdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave &raquo;</TD></TR><TR><TD CLASS="quote">yeah from that last pic it almost seems to have a slight incline at the bottom. </TD></TR></TABLE>
It's seems like that to me too.
if you can clock it a little more i would becuase that could be an easy $300 mistake you could fix.
Old Dec 14, 2004 | 01:08 PM
m R g S r's Avatar
Default Re: Check my oil return (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
if you can clock it a little more i would becuase that could be an easy $300 mistake you could fix.</TD></TR></TABLE>
Ehh. . Mine is worse, but I couldn't put it any other way. My turbo seals are still okay. . I think. . .GT32E turbo btw.
Old Dec 14, 2004 | 01:16 PM
racinskittle's Avatar
it looks like it's fine. As long as it all slopes down. The oil get's pretty thin once it's hot so I dont think it'll have any problem flowing even if it's cocked foreward.
How long after the bend does it extend? Any way to shorten it? That's all I'd be worried about. Actually, it looks pretty short. I think you're good.
Old Dec 14, 2004 | 01:36 PM
Rod.'s Avatar
Default Re: Check my oil return (racinskittle)
looks good but toward the top looks lil bulky
Old Dec 14, 2004 | 01:54 PM
adseguy's Avatar
Default Re: Check my oil return (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Ehh. . Mine is worse, but I couldn't put it any other way. My turbo seals are still okay. . I think. . .GT32E turbo btw. </TD></TR></TABLE>
I don't get it though. You can clock the oil inlet and outlet (is that the center cartridge?) seperate from the compressor and turbine. So why not clock it the way you want? Please explain a little
Old Dec 14, 2004 | 03:00 PM
stealthmode62's Avatar
There's no problem with that drain. The only thing I couldn't really see is where on the oil pan it's tapped.
Old Dec 14, 2004 | 04:49 PM
nonvtecD's Avatar
It's tapped high on the pan, no it doesn't slope up, that is just the angle of the picture, it gets almost flat but that's it. If I clock it anymore my oil feed hits the manifold, thats another thing.
Old Dec 14, 2004 | 06:36 PM
EJ1 wilcox's Avatar
Default Re: (D15B7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B7turbo &raquo;</TD></TR><TR><TD CLASS="quote">It's tapped high on the pan, no it doesn't slope up, that is just the angle of the picture, it gets almost flat but that's it. If I clock it anymore my oil feed hits the manifold, thats another thing.</TD></TR></TABLE>
Ahhh... same problem I encountered...
I ended up flipping the turbo around because I didn't want to worry about the angle of the cartridge... like this...
This way I can run the cartridge perfectly vertical and I don't have to worry as much about my seals...
Old Dec 14, 2004 | 09:59 PM
Default Re: (EJ1 wilcox)
If you took the feed flange off you could tap the hole to the correct size and give yourself enough room, but whatever works.
Old Dec 31, 2004 | 09:30 PM
Curtis2kul's Avatar
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">If you took the feed flange off you could tap the hole to the correct size and give yourself enough room, but whatever works. </TD></TR></TABLE>
i wonder if that would work for the return also. im using the hf amnifold and it sits the turbo so damn low
srg
Aug 12, 2006 12:53 PM
88crxhfb16
Jun 27, 2005 08:53 AM
tub_sephiroth
Apr 3, 2005 02:25 PM
mike1114
Mar 28, 2005 08:01 AM
D A 9
Jul 27, 2003 05:16 AM
