Check engine :air temp sensor
Old Apr 26, 2005 | 08:22 PM
turbo95eg6's Avatar
Default Check engine :air temp sensor
so got the car dyno tuned, 14psi and my cel light goes off....replaced the air temp sensor in the intake mani, light still goes on. What should i look for...?
Old Apr 26, 2005 | 08:25 PM
s2kdre's Avatar
Default Re: Check engine :air temp sensor (turbo95eg6)
whats the set up? do you have a 3 bar map or stock?
Old Apr 26, 2005 | 08:30 PM
turbo95eg6's Avatar
Default Re: Check engine :air temp sensor (jdmhonda)
3-bar. Just got tuned on hondata.
Old Apr 26, 2005 | 08:44 PM
turbo95eg6's Avatar
ump
Old Apr 26, 2005 | 09:03 PM
raene's Avatar
If the sensor's known-good, check the wiring. Trace the pins on the harness back to the pins on the ECU.
Old Apr 26, 2005 | 09:13 PM
turbo95eg6's Avatar
Default Re: Check engine :air temp sensor (raene)
so i should check the wiring. K. Will do. Anything else...? Is this due to me adding hondata or adding more boost...?
Old Apr 27, 2005 | 08:07 AM
raene's Avatar
Neither should have an effect on this, no!
luckii
Nov 10, 2008 06:12 PM
pancake
May 4, 2008 02:17 PM
nObOdy65
Feb 15, 2006 11:44 PM
civicdragger818
Feb 16, 2003 07:14 PM
