changing map sensor: tuning needed?
Old Apr 5, 2004 | 02:18 PM
redboost10's Avatar
Default changing map sensor: tuning needed?
if i were to switch my 1bar map sensor with a 3bar, would i have to get tuned again after changing them or will it stay the same? thank you.
Old Apr 5, 2004 | 02:22 PM
asiangl2's Avatar
Default Re: changing map sensor: tuning needed? (tgh99si)
when i had my 3 bar installed i had to get it tuned, but i have hondata. To my knowledge the three bar changes voltage reading from the map from 2.65 to 1.6 or so volts. What is your setup.....???
Old Apr 5, 2004 | 02:33 PM
tegmech's Avatar
Default Re: changing map sensor: tuning needed? (asiangl2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asiangl2 &raquo;</TD></TR><TR><TD CLASS="quote">when i had my 3 bar installed i had to get it tuned, but i have hondata. To my knowledge the three bar changes voltage reading from the map from 2.65 to 1.6 or so volts. What is your setup.....??? </TD></TR></TABLE>
I am unsure to why you need to have it retuned again. Are you meaning that you have to just change to 3 bar (i know you have to do that), or are you having to retune fuel maps?
Old Apr 5, 2004 | 02:45 PM
redboost10's Avatar
Default Re: changing map sensor: tuning needed? (tegmech)
right now its tuned and i have a gm 1bar map sensor on it. but i recently bought a gm 3bar map sensor and i was wondering if i could just install the 3bar and call it good or do i have like retune it once i switch to the 3bar?
Old Apr 5, 2004 | 03:41 PM
TravSi's Avatar
i would retune.....any changes you should re-tune because a cars "tune" changes day to day...depending on conditions, Its better safe than sorry....
Old Apr 5, 2004 | 03:42 PM
redboost10's Avatar
Default Re: changing map sensor: tuning needed? (TravSi)
alright, thank you. i wasnt sure if it affects the previous tune or not
Old Apr 5, 2004 | 03:48 PM
Cyphear's Avatar
all you have to do is tell it you have a 3 bar and burn a new chip. The fuel maps will still be the same... with different boost scalars of course.
Old Apr 5, 2004 | 03:52 PM
redboost10's Avatar
Default Re: (Cyphear)
ok, thanks man
Old Apr 5, 2004 | 03:56 PM
kpt4321's Avatar
Right. You can't just plug it in.
You need to rescale the maps in the ECU. You don't need to actually retune.
Kid_SiR
Dec 28, 2007 03:07 AM
90TegraB18C
Dec 11, 2006 08:20 PM
Greg H
Sep 23, 2006 06:58 AM
BigMoneyP
Sep 9, 2005 02:22 PM
Derek14
Apr 28, 2004 09:18 AM
