changing map sensor: tuning needed?
when i had my 3 bar installed i had to get it tuned, but i have hondata. To my knowledge the three bar changes voltage reading from the map from 2.65 to 1.6 or so volts. What is your setup.....???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asiangl2 »</TD></TR><TR><TD CLASS="quote">when i had my 3 bar installed i had to get it tuned, but i have hondata. To my knowledge the three bar changes voltage reading from the map from 2.65 to 1.6 or so volts. What is your setup.....???
I am unsure to why you need to have it retuned again. Are you meaning that you have to just change to 3 bar (i know you have to do that), or are you having to retune fuel maps?
</TD></TR></TABLE>I am unsure to why you need to have it retuned again. Are you meaning that you have to just change to 3 bar (i know you have to do that), or are you having to retune fuel maps?
right now its tuned and i have a gm 1bar map sensor on it. but i recently bought a gm 3bar map sensor and i was wondering if i could just install the 3bar and call it good or do i have like retune it once i switch to the 3bar?
