Center housing not rotating....
Old May 14, 2005 | 07:05 AM
92civicb18b1's Avatar
Default Center housing not rotating....
I recently rebuilt my t3 42/48. But I never was able to rotate the center housing. Is there a way to break it loose? Every bolt except the two bitch bolts are out and the bitch bolts are loosened. I sprayed some wd40 but didn't go overboard. I was wacking the hell out of it, but I don't want to wack it too hard and throw it out of balance.
So any ideas. I need to figure this out so I don't blow the seals....again.
Old May 14, 2005 | 09:17 AM
Default Re: Center housing not rotating.... (92civicb18b1)
Old May 14, 2005 | 10:40 AM
Sonny's Avatar
Let that thing soak with a generous amount of PB Blaster. If it still won't budge, you're gonna need some heat.
Sonny
Old May 14, 2005 | 01:39 PM
Default Re: Center housing not rotating.... (Sonny)
Thanks, I'll try.
Old May 14, 2005 | 02:18 PM
TURBO DC2's Avatar
ya I'd spray it with some PB and just let it chill for a bit. Should break it loose.
g2turbo
Mar 10, 2016 04:24 AM
nico.tico
Nov 19, 2010 05:17 PM
redDAinteg
Jun 26, 2006 03:49 PM
delslo93
Jan 23, 2005 12:31 PM
Dawson21
Jun 6, 2004 07:58 AM
