cell problem
Old Jun 11, 2009 | 09:33 PM
thid92's Avatar
can I haz?
Default cell problem
I am running a B20 vtec sleeved with GE to 85 mm 750 RC injectors Victor X mani and a drag turbo kit with a P72 ecu and a 3bar installed running 11-15PSI. problem is after I start the car i get a cell but it I cant read it with the paper clip solution, it wont stay after i shut it down and turn the key. how do i find out what the code is? I am trying to get my set up tuned but dont want to show up with any cells... I had the car tuned before but i dont think the guy knew what he was doing as my motor had to be rebuild twice after the shitty tune he programed also the car runs really shitty in the low rpm's after it gets warmed up and most of the time it stalls.
Old Jun 12, 2009 | 05:07 AM
ef92b's Avatar
Default Re: cell problem
when CEL turns on, jumper the SCC while engine's running, no need to turn off the motor.
Old Jun 12, 2009 | 05:20 AM
thid92's Avatar
can I haz?
I tried it but i get nothing the cell just stays lit up no blinks or anything.
Old Jun 12, 2009 | 05:35 AM
ef92b's Avatar
are you using an aftermarket ignition wires set? replace it with the OEM pieces and test. you might be experiencing some electrical interference causing your ECU to post a CEL.
Old Jun 12, 2009 | 05:37 AM
HarfordCTR's Avatar
What engine management you running?
Old Jun 12, 2009 | 07:33 AM
dpetro1's Avatar
solid CEL could also mean malfunctioning ECU. might try to swap with another
Old Jun 12, 2009 | 10:15 AM
thid92's Avatar
can I haz?
i am not sure what he tuned with but think it was crome. so its possible that the ECU is bad also? I had a P28 with hondata S200 boost that he fried on me and replaced it with the P72, I am thinking I am just going to go back to the P28 and see it the tuner will be able to get a good tune on it.
thanks for the replies.
Old Jun 17, 2009 | 03:55 PM
thid92's Avatar
can I haz?
Ok the ECU is reading a cell 14 what code is that for OBD1 P72 I cant find the post with the cell codes table.
Old Jun 17, 2009 | 05:06 PM
SilverEk3dr's Avatar
says Idle air control valve or BAD ECU
Old Jun 17, 2009 | 07:19 PM
thid92's Avatar
can I haz?
thank you, my idle is ****. it surging really bad so maybe its just my IAC.
Old Jun 18, 2009 | 06:17 AM
dpetro1's Avatar
make sure its plugged in correctly and that it didnt get mixed up with another sensor. looks like it needs to be replaced though.
Old Jun 18, 2009 | 06:47 AM
d16z6Tcrx's Avatar
are you using a jumper harness? i had a code 14 from a loose wire in the jumper harness.
also what injectors are you running?
Old Jun 18, 2009 | 07:39 AM
thid92's Avatar
can I haz?
I got my orig harness 92 civic Si obd1, running RC 750 cc injectors also a 3 bar map. could it be anything to do with the 3 bar map being hooked up wrong?
Old Jun 18, 2009 | 11:01 AM
d16z6Tcrx's Avatar
well did you wire it right? also are you runing 11 OR 15psi? is the computer set to read a 3 bar map?
a code 14 is pretty cut and dry. its either the iac itself or the wiring.
also make sure you properly burped the cooling system.
Old Jun 18, 2009 | 11:26 AM
thid92's Avatar
can I haz?
right now its set at 11 psi, as far as the tune i am not sure because the tuner ****ed all sorts of **** up. not excatly sure how to burp the cooling but i filled it to the top idled the car and topped off as the level went lower and repeated til the level wouldnt move.
I dont see how I would get a code 14 from having an air pocked though, even though i diid get rid of them. only thing i could see is the IACV or the wiring being messed up to the 3 bar map for the code to show up. I unplugged the 3 bar map and the engine would not respond at all to any throttle given.
now the car runs at around 1200-1400 rpms when started then dropps down and almost stalls when warmed up.
Old Jun 18, 2009 | 02:17 PM
d16z6Tcrx's Avatar
ok lets back up a bit.
you have code 14. iac valve circuit. its 2 wires. one gets 12v(yellow/black) from the main relay. the other is signal.
check to see if you get 12v at that wire if not you have an open somewhere. then ground pin a9 at the ecu with the key on and see if you can hear the iac motor clicking on and off as you tap it to ground. if it does not click check continuity on the blue/black wire to the iac. if its good the iac is bad.
Old Jun 18, 2009 | 04:31 PM
thid92's Avatar
can I haz?
ok i am no expert with electronics but i pretty sure i can figure this out, i dont have a volt meter but gonna see if i can borrow one.
thanks for the good info.
Charlie Moua
Sep 29, 2014 04:37 AM
tdo
Aug 11, 2009 07:46 PM
khmboostedeh2
Apr 1, 2006 07:09 AM
FOrSfEd
Jul 18, 2005 09:41 AM
USDMGD3!
13
Jun 6, 2004 10:20 AM
