catch can yes or no?
Old Jan 6, 2010 | 06:39 PM
j.packsb's Avatar
Default catch can yes or no?
im runnin a boosted d16 on 9 lbs and my pcv black box is leaking lots of oil. im currently jus using the stock pvc layout except im using a brethe ron the valve cover. does anyone kno if switchin to a catch can would leviate any pressure and stop the leak? and if so, how should i route the lines for the can? ive seen so many ppl argue different ways to runner and i need some guidance from HT...
Old Jan 6, 2010 | 06:49 PM
boostedEF91's Avatar
Default Re: catch can yes or no?
on 9lbs you should be fine with the stock system. i ran it on my old d series for a long time. maybe you're black box is bad and needs replaced.. or you could book up a catch can from the black box and maybe vent the valve cover..
Old Jan 6, 2010 | 07:10 PM
j.packsb's Avatar
if i were to run a can just for the added benefit, should i jus replace the black box that is leaking or should i remove and run a fitting from the hole on the block? is there a fitting that will just fit into that hole or what? im really lost and confused with this and i need to get the car running asap! plz help!!
Old Jan 6, 2010 | 07:38 PM
cleansi's Avatar
there are sooo many write ups on catch cans JUST SEARCH!!!
if i ran any boost at all i would recommend a catch can
n/a runs catch cans 2 the purpose is to elimnate or fix oem pcv system
Old Jan 6, 2010 | 08:47 PM
boostedrexy's Avatar
yeah there is a fiting that will fit in that hole... you can run line from that to the can and one fron the valve cover. also
Old Jan 7, 2010 | 03:47 AM
j.packsb's Avatar
i kno there are plenty of write ups. almost like there are too many. too many ppl go bak and forth on different things. i jus wanna kno if i remove the black box, what size fitting will i need? ive read somewhere that you can use a 3/8" brass fitting. but ive also heard something about having to plug the hole for the black box? so im a little confused and need a straight up answer as soon as possible...
Old Jan 7, 2010 | 04:16 AM
Remove the black box. clean it and what not. make sure its not leaking do to being old or the o-ring around it isnt damaged. put black box back on. run a breather line from the black box to a catch can. and 2 off the valve cover if you still have problems.
Old Jan 7, 2010 | 05:20 AM
j.packsb's Avatar
so ur saying remove the actual pcv valve and just replace it with a hose to run to my catch can? i also read i can tee into that line from the pcv box with a line from the vakve cover to make a "sealed circuit" is this a good idea. and should i be getting a can with a filter on to[ or does that not matter?
Old Jan 7, 2010 | 04:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
in the faq's there are like 4 threads strictly related to catch cans, and many others that arent listed. i am not locking because i have to ask a question, if oil is really puking from the black box, how mechanically sound is the engine? (im asking what the condition of the rings are) if the rings are toast, a catch can will just give you a place for the oil to go, not fix why it is getting there in the first place.
Old Jan 7, 2010 | 04:34 PM
cooljnateman's Avatar
yes is the simple answer if your looking for reliability on the real, the more little things u do to make it safer the better think bout it
Old Jan 7, 2010 | 05:13 PM
99kleansi's Avatar
hmm Im having the same problem using the black box as a vent. Oil still leaking on a just built motor. Intermittent smoking from the exhaust as well. Thinking the smoking is related to Turbo seals which is also brand new from Precision.
Old Jan 8, 2010 | 05:29 AM
nextproject97's Avatar
Heres a link for a set up that works perfectly for me I run a supercharged gsr at 11+ psi and was having issues with my stock set up. It still uses the black box but it gets modified. I attached a pic of how to modify it and attach the hoses .Otherwise you can just send them your stock black box and they can modify it for you and send it back with the kit .I really like this set up it has pretty much eliminated the smoke in my exhaust under hard acceleration . Its also a maintenance free set up http://www.theoldone.com/components/breather/
Old Jan 8, 2010 | 05:38 AM
seems like a good setup.
Old Jan 8, 2010 | 05:58 AM
Well I just realized you said you have a " d " 16 .I did not see that and dont think the kit I posted will work for the d series but you could however call Larry at Endyn and ask what he recommends sorry for not reading the post properly the first time .But for any of you b series guys this kit works well for me .
br8crumb
Feb 18, 2015 07:25 AM
93 Eg Couper
Oct 4, 2010 01:24 AM
boostedteg4dr
May 12, 2008 01:29 PM
b18-c-rx
Jul 2, 2005 06:59 PM
stevel
26
Jul 19, 2004 11:51 PM
