catch can smoking
Old Apr 23, 2009 | 07:15 PM
rudedawwg's Avatar
Default catch can smoking
so here is my setup
fully built bottom b16 end and top, peakboost ac kit and a 57 trim garrett. my issue is with my breather. before i installed my catch can i smoked a lot out of my breather on my valve cover. after installing my catch can it does the same thing but only out of the catch can. its the endyn one with 2 -10 lines going to my valve cover and a drain back to my block. i heard a little smoke is normal but mine is doing it A LOT!!!! HELP
Old Apr 23, 2009 | 08:33 PM
jdm inc's Avatar
Default Re: catch can smoking
had this happen befoe and it ended up being a cracked piston had really bad blow by and smoke just keep comming out of the breather....
Old Apr 24, 2009 | 05:53 AM
boosted91crx's Avatar
they always smoke when you first start the car or under load but once warmed up and at idle it should all but stop or even stop. if it dont do a leak down test right away and see what the results are.
Old Apr 24, 2009 | 06:09 AM
redlinetuning's Avatar
Is smoke coming out from anywhere else?
Old Apr 24, 2009 | 06:13 AM
rudedawwg's Avatar
i am almost positive its not a cracked piston. took the head off last week and they looked to be good. i did a comp test 2 months ago and the numbers were where they were supposed to be.
i will try the leakdown test but what will that prove for my smoke in the catch can??? also is it normal to have the tiniest bit of oil in your radiator/coolant.... not coolant in your oil but oil in your coolant? because i do have that issue and im not sure if thats causing the smoke
Old Apr 24, 2009 | 06:31 AM
there should never be oil in the coolant, the leak down test will tell you if any cylinder has a problem that can allow extra blow by ( smoke) past the piston and thus out the breather or catch can. often a cranking compression test can miss a problem. what i like to do as well is while the leak down test is being done have the rad cap off and fill it all the way full and watch for air bubbles during the leak down test, if you get any on a particular cylinder thats bad .
Old Apr 24, 2009 | 08:57 AM
jdm inc's Avatar
we couldnt tell either by looking at the pistons with the head off till we took the actual piston out and where the rings were a big chunk was cracked.... But i would do a leakdown test like boosted91crx said good luck.
Old Apr 24, 2009 | 04:23 PM
K i l l a B e e.'s Avatar
this a new motor? what did you gap your rings at?
Old Apr 24, 2009 | 05:35 PM
Bailhatch's Avatar
The ring gap would have to be massive to get any real noticable smoke in the crankcase. I've done it hehe
Old Apr 24, 2009 | 09:26 PM
rudedawwg's Avatar
i bought the motor already built so im not sure. but i had a honda master certified mechanic dissamble the motor to look at it and according to him everything was fine
Old Apr 24, 2009 | 09:44 PM
eg:R's Avatar
x2, gapping rings to big can cause more blowby
Old Apr 25, 2009 | 05:22 AM
Alfa Turbo's Avatar
How much is a lot? One of the by products of combustion is water. It can make it's way out as a vapor from the breather and will generally go away once the engine warms up. A little water also gets in the oil and will not go away until you get the oil good and hot.
So... define how much.
If you are certain your compression tests are good I would think you have nothing to worry about. With that being said, excessive blow-by is usually a sign of bad rings, cracked rings, broken ringlands... etc. But if this was the case you would not have good compression results.
Good luck.
Old Apr 25, 2009 | 05:15 PM
cjordan's Avatar
just like stated above my catch can smokes during warm up, and when under extreme load.
Old Apr 27, 2009 | 12:16 PM
eg:R's Avatar
i have blowby on my valve cover because i gap the rings to much. i think it was 20 and 24. just redid my rings to 20 and 16. no more blowby
Old Apr 27, 2009 | 07:42 PM
i need to redo my rings also. i have blowby coming out of the dipstick =/. I took off my head to get redone and my machinist told me that the valves werent seating. I was banking on hoping that that would be the problem for my blowby. I slapped the head back on and it still has blowby like a ****.
time to tear down the block and regap the rings!
by the way, thats the downside of driving it with the rings gapped too large?
Old Apr 28, 2009 | 07:18 AM
rudedawwg's Avatar
has anyone heard of a catch can smoking a lot due to a blown turbo. if i remember correctly i always has a minimal amout of smoke just coming out of my breather on my valve cover, but i didnt actually install my catch can until my exhaust side seal became bad on the turbo.
as for the ring gap size..... are there no hazards of running to big of a ring gap????
Old Apr 28, 2009 | 07:26 AM
Si GUY99's Avatar
If he has oil in his coolant where could that have come from? since he's not running a gt unit
Old Apr 28, 2009 | 08:47 AM
rudedawwg's Avatar
???? wondering that myself
Old Apr 28, 2009 | 10:33 AM
HondaKylehasnolife's Avatar
New User
mine smokes too but i still think i'm hella fast!
Old Apr 28, 2009 | 08:52 PM
rudedawwg's Avatar
well im still fast but mine is a daily driver... thats why i ran the peakboost ac compatible kit. i just want to know what i should do about getting my **** fixed
Jennperry32
Apr 16, 2013 07:55 AM
soontobeboost
May 24, 2006 10:44 AM
Ls-Turbo
Dec 11, 2005 10:30 AM
stegon78
Apr 11, 2005 06:55 AM
vtec.dc2
Jan 14, 2005 11:41 PM
