catch can setup. Sensor on block plug, what is it for?
Old Apr 30, 2013 | 12:01 PM
WAUKEENEM1's Avatar
Default catch can setup. Sensor on block plug, what is it for?
ok, so i took out the black box and the two 14mm plugs for catch can setup.
everything when well except the 14mm plug on the left,next to the ops. that plug had a sensor in it. finally found the right size socket to get it out. 34mm
my ? is what is that sensor for? it doesn't connect to any anything. it's green.
from all the pics i found online, those two block plugs doesn't have a sensor on it.
btw, it's on a jdm b16a block. n no oem oil cooler either.
thanks
will post a pic soon.
Old Apr 30, 2013 | 12:09 PM
vtechjunkie's Avatar
Default Re: catch can setup. Sensor on block plug, what is it for?
It's your oil pressure sending unit, it plugs into your harness via a little sheathed metal clip. Like the one on the side of your head(coolant temp sensor), but for your oil. The harness' plug will look the same though.
Old Apr 30, 2013 | 12:29 PM
WAUKEENEM1's Avatar
i don't think it's that cuz i tee off the opsu for the turbo feed line. this sensor is about an inch round/wide.
Old Apr 30, 2013 | 01:19 PM
nealnanoHX's Avatar
It could be a ghetto rigged knock sensor, pics would help. If it is a knock senor and your running OBD1 and tuned (I hope so you since it says 99 EM1 turbo) you will not need it.
Old Apr 30, 2013 | 02:21 PM
WAUKEENEM1's Avatar
ok, found some pics online of sensor.
1st pic is the sensor in green
2nd pic...no sensor on block plug.
Old Apr 30, 2013 | 02:33 PM
Turbo-LS's Avatar
Its an oil temp sensor used in the earlier B series blocks i believe obd0 and early obd1. Ive seen them on b18a motors
Old Apr 30, 2013 | 02:38 PM
WAUKEENEM1's Avatar
that's what i thought too. thanks
Old May 2, 2013 | 04:22 PM
dpetro1's Avatar
found this on an old thread
Old May 3, 2013 | 05:03 AM
WAUKEENEM1's Avatar
i wonder if u can hooked up those two sensor(black/red) to an aftermarket oil temp and coolant temp gauge.
Old May 3, 2013 | 08:30 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
They are just switches, not sensors. They are either closed or open.
Jaz760
Apr 7, 2012 06:37 PM
Japankid
Welding / Fabrication
Apr 9, 2009 12:35 PM
gen2fanatic
Feb 28, 2007 07:09 PM
scrubachu
Apr 4, 2005 02:42 PM
tradesalot
Sep 19, 2004 09:23 PM
