Catch Can Question ?>
Old Jan 14, 2009 | 09:37 AM
Joeski99Si's Avatar
Default Catch Can Question ?>
im looking into getting a catch can for my turbo civic w/b16.. . Im just wondering weather i should get a catch can or one of the breather cans with the filer on it ? ? ? suggestions
i read once on some website (that i cant find again) somthing about the regular catch cans being better then the ones w/breather filter . . ? ? ?
Also anyone using a catch can, suggest what company's make good ones?
Old Jan 14, 2009 | 09:49 AM
6000pounds's Avatar
Default Re: Catch Can Question ?>
I got mine from Greddy a couple days ago. They make two different size fittings. Either a 9mm or 12mm. Don't be a dumbass like me and get the 12mm fittings. You will be buying hose adapters and zip tieing **** all over the place. 9mm is more than enough for a DD. I jsut ran a breather filter off of my valve cover and ran the vaccuum line to my manifold.
After I understand the simplicity of a catch-can I'm surprised cars don't come with them stock from the factory.
Look at it this way. If you have ever smoked "tabacco" out of a "tabacco" pipe you can see the amount of resin that builds up over time. That's the crap you are sending back into your engine. Why recycle that bullshit if you can dump it out and keep your engine clean. Well at least that's the way I see it in my head
Old Jan 14, 2009 | 10:09 AM
boostedcivicsir's Avatar
Mr. Badwrench
in the faq's there are atlease 5 threads that i know of devoted to catch cans.
and there isnt anything wrong with a drainback especially if your can cant hold the ammount of oil it is passing on a run.
why do all the fast guys use drainbacks?
im not arguing, our cars get oil changed every couple passes.
IntegraType-R
Jun 9, 2006 11:43 PM
SPOOLINmatt
Jun 21, 2005 09:28 AM
Prelude91siT
Jan 1, 2004 10:42 AM
redtegger03
Jun 25, 2003 10:41 AM
1.8T_EG
Aug 13, 2002 01:21 PM
