Which Cat?
Old Aug 26, 2002 | 01:37 PM
Cyrio's Avatar
Default Which Cat?
What would be a good high flow cat that fits to a Thermal 3'' exhuast? If there isn't any that fit, how much would it cost to have a muffler shop weld on a universal cat?
Thanks for the info.
Old Aug 26, 2002 | 01:43 PM
GSRwBOOST's Avatar
Default Re: Which Cat? (Cyrio)
uh.. whats a cat?
<--- runs home to see if he still has his in the garage...
Old Aug 26, 2002 | 01:56 PM
Mase's Avatar
Carsound high flow cats are good. or so i hear, thats what im going to be ordering
Old Aug 26, 2002 | 02:02 PM
Cyrio's Avatar
Default Re: Which Cat? (CDooMe2)
Is there a specific cat that fits to the exhaust? As in to ask, does anyone have a part number?
Old Aug 27, 2002 | 07:25 PM
Cyrio's Avatar
Does anyone know if they make one that would fit a thermal r&d 3'' exhuast for a 98 integra?
Old Aug 27, 2002 | 07:49 PM
RicerRacing69's Avatar
<---straight pipe, less money with more HP, just sux when emission time roles in
Old Aug 27, 2002 | 08:06 PM
Cyrio's Avatar
Default Re: Which Cat? (RicerRacing69)
I can't do that, I live in California. Someone please answer the question.
Old Aug 28, 2002 | 04:37 PM
Cyrio's Avatar
ttt
Old Aug 28, 2002 | 04:49 PM
20lb.teg's Avatar
Carsound cats are the best, and a 94100 series 3" with no air should be a good replacement it's about the size of a GSR's, flows enough to support 360 CI (or a 5.9L) engine, and will support a 600 lb. vehicle and remain CARB approved. That is the one that I run on the street when I have an exhaust. And I would recommend it to anybody running a full 3" turbo exhaust. Hope this helps
Later,
Sean C.
Old Aug 28, 2002 | 04:55 PM
20lb.teg's Avatar
Default Re: Which Cat? (20lb.teg)
And sorry it's the 94100 series but the exact part # (the 3" with no air tube) is 94102. And just to add, the dimensions are 13" long tip to tip. 9" for just the convertor, 6.5" wide and 4" tall. Here is the picture of the dimensions:
Hope this helps,
Later,
Sean C.
Old Aug 28, 2002 | 05:34 PM
98civicEX's Avatar
do a search on b18bturbo, i just bought my 3" resinator/cat off him for $75.00 , viren =
Old Aug 28, 2002 | 05:47 PM
98civicEX's Avatar
Default Re: Which Cat? (98civicEX)
https://honda-tech.com/zerothread?id=247516
there u go
Old Aug 28, 2002 | 06:15 PM
SilverLudeSi's Avatar
New User
Yeah, but I am pretty sure that's just a resonator. It doesn't function as a cat at all, it just fits where a cat would normally go. So it wouldn't be what this guy needs. I would go with carsound 3" as everyone else said.
Old Aug 28, 2002 | 06:25 PM
B18EG6's Avatar
Default Re: Which Cat? (SilverLudeSi)
well it wont work as a cat, but i drilled the middle of mine out and gutted it with a railroad tie...
how do you spell "illegal"
Old Aug 28, 2002 | 07:30 PM
20lb.teg's Avatar
Default Re: Which Cat? (B18EG6)
Well, you know how the part of the jack that you... well jack... The handle well on my jack it's a split handle, meaning you can take a bolt out of it and make it shorter, well i just took that half off and peat the end of that with a hammer to hollow out (gut) my stock cat before I got my all custom #' Turbo back exhaust with the custom Carsound cat. It worked fine and had this infectious smell when I was running on 110 octane!!!! That was some good stuff! hope this helps.
Later,
Sean C.
00siandrew
May 11, 2006 05:09 PM
SpoonLx
Jan 19, 2005 10:49 PM
Pfieff
Sep 12, 2003 01:59 PM
96tegsr
Jun 17, 2002 11:44 PM
