does it matter where you put the oil restrictor?????
i just purchased this oil restictor
well i think its gonna be a pain in the *** to get in the turbo just because of how the manifold gets in the way. is it possible to put the restrictor right where the oil pressure source is? does it even make a difference???
kinda like this
Modified by integra3586 at 9:25 PM 2/12/2007
kinda like this
Re: does it matter where you put the oil restrictor????? (SOHCmaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 »</TD></TR><TR><TD CLASS="quote">im just purchased this oil restictor
kinda like this
You need to check the pressure at the turbo to make sure you have no more than 55 psi and no less than 35psi at wide open. For the best spool and life of the unit you need to try and get to 40 psi and no it does not matter where you put the restrictor it just has to be before the turbo in the feed line.
The fitting you have a picture of is one that goes in the inlet of the turbo.
kinda like this
Re: does it matter where you put the oil restrictor????? (integra3586)
my buddies put it where you want to put it and it works fine. so i would think its fine.
If your turbo and your block fitting share the same 1/8 thread size, you can put it in either spot. If the restrictor fitting has a thread size other than 1/8, it has to go in the turbo.
Re: does it matter where you put the oil restrictor????? (PhantomX)
extremepsi.com it was $17, atp turbo sells them too, but i couldnt get there website to work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 »</TD></TR><TR><TD CLASS="quote">extremepsi.com it was $17, atp turbo sells them too, but i couldnt get there website to work </TD></TR></TABLE>
Wow, 17$ for that?
17.95 for this, with gasket and bolts.
Wow, 17$ for that?
Re: (taggart_lumpy)
I got mine free when i bought my 35R.. the fitting was already on the center section when i recieved it.. I was kinda suprised because I thought i had to buy one..
and btw, you should put it at the turbo..
Re: (92HB_HB)
fyi.....ball bearing turbo's have the restrictor built in, they also need a different amount of oil than a standard journal/race bearing.
Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">fyi.....ball bearing turbo's have the restrictor built in</TD></TR></TABLE>
you sure? i never knew that...
Re: (JST1CAM)
Don't forget that you can pick up a restrictor in with any size hole you want from Mc Mastercarr for less than $5.
I bought all my oil lines including block bspt fitting, a firewall T, and a restrictor fitting all for less than $50 shipped.
Sorry if it's OT, but it just kills be seeing people spend so much money on their oil lines and fittings when you can get them for so cheap.
P.S. in that picture it doesn't look like it's got the same threads on both sides of the fitting.
Re: (alex_s817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 »</TD></TR><TR><TD CLASS="quote">who is Mc Mastercarr? </TD></TR></TABLE>
http://www.mcmaster.com/
Re: (JST1CAM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JST1CAM »</TD></TR><TR><TD CLASS="quote">If you put it on the turbo how to do you check to see how much oil psi the turbo is getting??</TD></TR></TABLE>
x2
x2
