car wont start when hot??
Old Mar 18, 2008 | 03:47 PM
lambertincorp's Avatar
Default car wont start when hot??
Hey guys i am having a problem, sorry if this is not the correct forum...My car starts fine when it is cold and when it heats up to operating temp if i turn it off than it will not start back up until it cools off again. What could be the problem? My tech is thinking either the main relay or it is a pickup on the distributer going bad and because my AEM is set up to need to see 3 clean signals before the car starts that it may not be getting these clean signals because a pickup on the distributer is bad(i have individual coils). Also he thinks that something in the AEM just has to be changed maybe. Any help at all is golden thanks a lot.
Old Mar 18, 2008 | 04:29 PM
JasonST's Avatar
Default Re: car wont start when hot?? (lambertincorp)
Main relay, main relay, main relay!!! To make sure, if it happens again, check to see if ur fuel pump primes and listen to hear the fuel relay CLICK when u turn the key to the ON position. If it is broken, u can just resolder it or buy a new one.
Old Mar 18, 2008 | 05:57 PM
coneheadsracing's Avatar
Default Re: car wont start when hot?? (JasonST)
Did this happen after a tune, or just out of the blue?
Old Mar 18, 2008 | 06:05 PM
B20EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Main relay, main relay, main relay!!! To make sure, if it happens again, check to see if ur fuel pump primes and listen to hear the fuel relay CLICK when u turn the key to the ON position. If it is broken, u can just resolder it or buy a new one.</TD></TR></TABLE>
Exact same thing happened in my ef. All you had to do was tap the main relay with a screw driver and the fuel pump would prime. And it did only happen when the engine/ outside temp was hot
Old Mar 18, 2008 | 09:06 PM
Garage 808 Hatch's Avatar
i've seen the same problems caused by a going bad ignitor or coil too.
Old Mar 19, 2008 | 09:12 AM
JasonST's Avatar
Default Re: (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">i've seen the same problems caused by a going bad ignitor or coil too.</TD></TR></TABLE>
x2........ Looks like u got a bit of diagnosing to do. Check to see what it is you're not getting, spark or fuel. Then go from there.
Old Mar 19, 2008 | 11:42 AM
Default Re: (JasonST)
i will have to check that each coil has its own ignitor.
i will change the main relay and see if that makes a difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">Did this happen after a tune, or just out of the blue? </TD></TR></TABLE>
out of the blue
out of the blue<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Main relay, main relay, main relay!!! To make sure, if it happens again, check to see if ur fuel pump primes and listen to hear the fuel relay CLICK when u turn the key to the ON position. If it is broken, u can just resolder it or buy a new one.</TD></TR></TABLE>
the fuel pump primes every time without hesitation i have a fuel pressure guage to make sure
Old Mar 19, 2008 | 12:07 PM
97grnrs's Avatar
i just fixed a nissan with this problem. turns out to be a bad dist. even got a new one from dist king online and same problem.. then got one from the dealer and car works fine.
Old Mar 19, 2008 | 12:15 PM
Default Re: car wont start when hot?? (97grnrs)
thanks bro
Old Mar 19, 2008 | 01:10 PM
Evilparadize's Avatar
This used to happen to a 93 Chevy S-10 I used to have. The solenoid that pushes the sprocket out in the starter used to get so hot, that the contacts will come loose or not make good contact. After the engine was cool enough, the truck would start without hesitation. I know they are 2 different types of cars but it's worth taking a look.
Old Mar 19, 2008 | 04:30 PM
97grnrs's Avatar
Default Re: car wont start when hot?? (Evilparadize)
i didnt even think of that. is it cranking but not starting or not even cranking?
Old Mar 19, 2008 | 06:10 PM
PHDZINE's Avatar
You need more cranking fuel in that temperature range that you are having a problem starting. Usually you need more cranking fuel when it is cold and start taking away cranking fuel as it gets hot but you always need more fuel than what the base fuel map has during cranking no matter what the engine temperature is.
Old Mar 19, 2008 | 07:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">You need more cranking fuel in that temperature range that you are having a problem starting. Usually you need more cranking fuel when it is cold and start taking away cranking fuel as it gets hot but you always need more fuel than what the base fuel map has during cranking no matter what the engine temperature is.</TD></TR></TABLE>
OK i will take a look at that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i didnt even think of that. is it cranking but not starting or not even cranking? </TD></TR></TABLE>
it cranks but will not start
car was fully tuned, this problem just started it has never happened before
Old Mar 19, 2008 | 07:40 PM
22psicrx's Avatar
I have the same problem, the dealer said change the main relay. I did and it still did it. Si I checked, it is not getting and signal uot of the injector. Checked all grounds to. I just got a removable steering wheel and I just leave it running.
Old Mar 19, 2008 | 08:48 PM
project dc2's Avatar
Default Re: car wont start when hot?? (22psicrx)
i got this same exactly problem on my supra unfortunately
twin turbo coils, aem
when the motors hot the car wont start for ****
Old Mar 20, 2008 | 09:01 AM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
car was fully tuned, this problem just started it has never happened before</TD></TR></TABLE>
In that case...I would do try and swap the entire distributor with a working one.
Old Mar 20, 2008 | 12:42 PM
Default Re: car wont start when hot?? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i got this same exactly problem on my supra unfortunately
hey how did that work out i am interested cause i am using gs 400 lexus coils?
dist is the first thing i wanna do but i want to check the sync on the aem to make sure it is the dist before i start swapping stuff out thanks for the info guys!!!
Old Mar 20, 2008 | 04:11 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22psicrx &raquo;</TD></TR><TR><TD CLASS="quote">I just got a removable steering wheel and I just leave it running.</TD></TR></TABLE>
ha ha Mr.Been style yo
Old Mar 20, 2008 | 05:22 PM
Default Re: car wont start when hot?? (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">
ha ha Mr.Been style yo </TD></TR></TABLE>
thanks for ur insight
Old Mar 20, 2008 | 05:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lambertincorp &raquo;</TD></TR><TR><TD CLASS="quote">
hrmm i have a 1995 supra nA turned into Twin turbo model
i havent fixed it yet.
my homies at redzone performance will be wire tucking/cleaning up the engine harness for me this coming week.
Old Mar 20, 2008 | 05:44 PM
oh ok right on bro good luck
Old Mar 22, 2008 | 11:32 AM
kdawgy2k1's Avatar
bout to check the sync on the aem to check if the dist is the problem any other ideas on what the problem could be?
Brand
21
Sep 8, 2022 09:39 AM
collkid
13
Sep 16, 2015 09:10 PM
nismogrendel
Apr 24, 2010 01:43 AM
90jdmcrxdude
Aug 5, 2006 07:34 AM
imoua
11
Jul 28, 2006 08:14 PM
