Car Overheats
Old Feb 19, 2002 | 11:40 AM
td04civic's Avatar
Default Car Overheats
I just installed the greddy turbo on my 93 civic and when i drive the car hard it starts to overheat. What do you think could be the problem? Should i replace my termostat? if i do, should i replace it w/ one thats a higher temp. rating or lower?
Thanks
Troy
Old Feb 19, 2002 | 12:24 PM
td04civic's Avatar
Default Re: Car Overheats (td04civic)
By the way when the car starts to overheat theres a smell coming from the exhaust or the motor. I can't really explain the smell, my friend said it smelled like ammonia. Could it be coolant? Does that mean it's the head gasket? Crap...what are the signs for a blown head gasket and how much do you think a shop would charge to install one? Thanks
Old Feb 19, 2002 | 12:48 PM
sgT's Avatar
sgT
i would try the head gasket.
not sure on the cost to replace. depends on where u go
Old Feb 19, 2002 | 10:10 PM
Ri5e's Avatar
Default Re: Car Overheats (sgT)
Radiator could be clogged. Friend had the same problem, replaced it with another one and it worked fine.
Does your radiator reservoir bubble? if so then that could be it.
tjcletzgo
17
Nov 10, 2011 03:51 PM
efjones9
May 1, 2009 06:48 PM
seditiouscivic
Apr 6, 2004 09:03 PM
5thgencivic
Mar 25, 2003 12:46 PM
