Car not starting..
Old Jan 15, 2006 | 03:39 PM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default Car not starting..
I had just finished installing a turbo on my 1993 civic DX and the only thing I touched other then the oil sender, was the brake boost vacuum for my BOV, I checked everything..
1. There is gas..
2. There is compression..
3. There is spark..
4. There is AIR!!!
Those 4 rules it should start, but my luck it isnt.. Any suggestions?
Old Jan 15, 2006 | 03:44 PM
The Weather Man's Avatar
..........do a compression test and leakdown test. Post the results - if you have fuel, spark, and compression - it has to be a mechanical problem somewehre.
Maybe the starter clutch is no good - maybe the starter isn't drawing enough amperage. Maybe your throttle plate is stuck...........start checking things over again.
FK00GSR
Apr 14, 2005 06:03 AM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
Log4n
Mar 15, 2003 03:41 PM
schwett
Mar 24, 2002 09:39 PM
