car bogs when going into boost
Old Oct 20, 2004 | 04:26 PM
sneezyh22a4's Avatar
Default car bogs when going into boost
hi all.
Am running a fully built h22a4 and when am driving as soon as my boost guage
says 0-5psi the car bogs bad then ofter 5psi the car pulls hard then i start to hear
a noise when i hit 12-15psi almost like a crackling sound my a/f ratio guage says am on the rich side. i add more fuel at certin rpms and the car run like **** and i dont want to take away to much fuel either.has anyone encounterd this with there boosted porject and if so what can i do to get my car running right?
thanks.
Old Oct 21, 2004 | 07:05 AM
PrettyLude's Avatar
take it to a dyno and tune it you will know for sure its right
Old Oct 21, 2004 | 08:23 AM
Turbo E's Avatar
crackling, sounds like pinging/detonation to me.
stop abusing your car till its tuned. you may want to back off the ignition while you're at it.
Old Oct 21, 2004 | 08:27 AM
ChrisRicketts's Avatar
Default Re: (Turbo E 604)
man..........you're more than half way there. you've got to get that thing tuned before you ruin a perfectly good built motor. i'd kill to have that built motor right now. if you're not gonna get it tuned then it was a waste of money, and you can make 500 right now by giving it to me. if you blow it up, you're gonna kick yourself for not selling it to me when it was worth something.
anyways.........get it tuned!!!! is the crackling sound the exhaust?
Old Oct 21, 2004 | 05:42 PM
the crackling noise comes from the motor.
i don't think it's detnation because my guage says am rich.i tought u only get detnation when you run lean.
Old Oct 21, 2004 | 05:50 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (sneezyh22a4)
what guage , your bling narrow band autometer guage???? damn you have a built motor and you dont know that your NOT supposed to go by that
Old Oct 21, 2004 | 06:02 PM
eg6turbo's Avatar
Default Re: (Hella_JDM)
lets be a lil more supportive...well this crackling noise is it...like a fast popping of popcorn noise...or a higher pitch noise...if its the pop corn popping it could be many things like ur plugs not gapped correctly or bad ignition rotor...give more details about motor and specs of ur fuel management as of right now...
Old Oct 22, 2004 | 05:37 AM
yes it sounds like popcorn haha its funny that comparision is dead on point man.
fuel specs:
255 lph intank pump
stock fuel lines
hi flow fuel rail
adjustable fuel puessure regulator set to 60psi
390cc injectors
v-afc
Old Oct 22, 2004 | 05:43 AM
motor is a h22a4 fully built bottomend bord out to a 2.5L
the head is off a jdm h22a i don't think there is any differnce between us and jdm though.
just tought you might want to know.
Old Nov 19, 2004 | 03:59 AM
Em0ne's Avatar
had to wake this up.... we put a h23a vtec in my boys 97 accord and he now has a greddy turbo kit.... it is doing the same thing!
he has 370 rc's that came w the greddy kit....
People have said that it's a nasty boost leak or the map reading boost... so...
<FONT SIZE="5">
help!!!!
</FONT>
Old Nov 19, 2004 | 04:14 AM
TonyTurbolude's Avatar
do u have a missling link installed. I had that prob right before i hit boost. The car would bog and make the noises u described. I installed the missing link and now everythign is perfect and iam about to hit my 500 miles for the break in. getting it tuned this next week
Old Nov 19, 2004 | 06:50 AM
The-LS's Avatar
Default Re: (OnePointSicks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointSicks &raquo;</TD></TR><TR><TD CLASS="quote">what guage , your bling narrow band autometer guage???? damn you have a built motor and you dont know that your NOT supposed to go by that</TD></TR></TABLE>
I'm with this guy and others to think you may be pushing too much timing. THe Autometer gauge is really useless after seeing a few in action. I was lucky to have a somewhat "accurate" one in my car. But my buddy had one and was "tuning" his car and thought all was close.... lots of green under boost so he's thinking... "I'm safe... its RICH in boost.... not optimal but SAFE". Finally he broke down to buy the PLX Wideband... what was he doing in boost? really richs with AF in the range of 14-15 AF. Get a wideband if you haven't already... we are all assuming you guys with problems are NOT using a wideband.
Old Nov 19, 2004 | 09:45 AM
db8sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneezyh22a4 &raquo;</TD></TR><TR><TD CLASS="quote">motor is a h22a4 fully built bottomend bord out to a 2.5L
just tought you might want to know. </TD></TR></TABLE>
Take your spark plugs out and chk to see if they are still ok, i had a similiar problem and what ended up happening was that i melted my plugs due to it running lean
I had my car supposedly tuned, w/ all the fuel and engine manegement
Old Nov 19, 2004 | 11:21 AM
Em0ne's Avatar
Default Re: (TonyTurbolude)
using a firewall mounted MAP with 4 check valves...so????????????????????????????
Old Nov 19, 2004 | 11:38 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneezyh22a4 &raquo;</TD></TR><TR><TD CLASS="quote">the crackling noise comes from the motor.
i don't think it's detnation because my guage says am rich.i tought u only get detnation when you run lean.</TD></TR></TABLE>
Ok, so you mean if I run 40 pounds of boost on my motor with 87 octane in it, it will run OK and not detonate as long as I keep the AFR below 14.7:1? LOL.
Seriously, don't **** around with trying to tune your motor off of a VAFC and an autometer narrowband gauge if you don't have a clue what you're doing.
lsvtechatch92
Nov 11, 2009 01:41 PM
sickcord
Feb 8, 2007 01:52 PM
underpressure02
Apr 24, 2005 04:16 PM
Andrew 825SM
Sep 22, 2002 01:26 AM
ezark
Jan 11, 2002 09:55 AM
