Car Bogging & Stalling - Plug Pic
Old Oct 30, 2005 | 06:33 AM
aalb1's Avatar
Default Car Bogging & Stalling - Plug Pic
Yesterday I removed my power steering using the Honda Tech PS Removal Kit by Padawan. Great and very complete kit by the way. Removing the pump a bunch of PS fluid spilt on my air filter. I tried to soak it up then I placed a rag over the top of the filter to catch anything else that spilt...not much more spilt.
Taking it for a test drive the car ran fine. Taking it out later that night after 20 minutes of driving it started to bog during acceleration...almost like I was learning to drive stick again. At certain times it even stalled at idle, but usually at idle and and at a steady speed it everything seemed normal. It was just bogging during acceleration and occasional stalling.
I thought that the air filter might have been clogged but I removed it and it still ran bad. It's been 3000 miles since I changed my plugs so I thought that might be the case. I did a compression test at the same time and compression was even. After throwing in new BKR7E's gapped at .028" the problem still occured. I checked my plugs and this is what I saw...
Sorry for the Camera pic but it's all I got.
Heavy soot and smelling like fuel. Apparently it's running rich...I think. Any suggestions on what to do?
By the way this car was tuned in April on Neptune.
Old Oct 30, 2005 | 08:27 AM
Pay2play killa's Avatar
Default Re: Car Bogging & Stalling - Plug Pic (aalb1)
CEL status?
you're definately running rich; could be a sesnsor thats going ape **** throwing the ecu into limp mode for a fraction of a second or longer.
Old Oct 30, 2005 | 09:08 AM
warrick's Avatar
check for kinks in fuel return line, since you were in that area with the PS stuff.
Old Oct 30, 2005 | 07:07 PM
aalb1's Avatar
Default Re: Car Bogging & Stalling - Plug Pic (warrick)
No CEL codes... what sensor could it be that's going??? I can only think of the O2 sensor I'm at 68K and don't they last for 60K miles give or take? Wouldn't I throw a code for that one too?
Old Oct 31, 2005 | 05:12 PM
aalb1's Avatar
Checked the O2 Sensor...I swapped it out with a good one and it still has problems...any other suggestions...I'm desperate.
Old Nov 1, 2005 | 12:11 PM
warrick's Avatar
if you have any working distributors around, try swapping out a cap, rotor, plug wires, or even the whole distributor. maybe you're getting weak spark.
civicEX1995
Honda Civic (2006 - 2015)
Jun 15, 2013 02:34 AM
david1227
Jun 2, 2013 11:50 AM
FBPPrelude
Dec 27, 2006 07:12 PM
. M i c h a e l
Oct 15, 2005 08:57 PM
skizot722
Jul 9, 2004 10:07 AM
