Speedometer and Odometer don't work, everything else does. Fixable? 1991 DA
Old Apr 8, 2011 | 10:51 AM
CubbyChowder's Avatar
Default Speedometer and Odometer don't work, everything else does. Fixable? 1991 DA
Just bought a 1991 DA that needs a lot of work, its basically just a learning project for me.
I noticed the Speedometer and the Odometer don't work, but everything else does. Is it possible that the previous owner just unhooked them to prevent miles adding up? Is that pretty common to do? Would it be hard to hook them back up? Any help would be awesome, thanks!
Old Apr 8, 2011 | 11:50 AM
takin8ez's Avatar
Default Re: Speedometer and Odometer don't work, everything else does. Fixable? 1991 DA
your speedo cable is broken, most likely due to excessive force upon removal of the cluster at one point in time. this is very common
Old Apr 8, 2011 | 12:54 PM
is the cable replaceable? how should I go about fixing this? any write ups?
Old Apr 8, 2011 | 08:01 PM
bump, anyone?
Old Apr 8, 2011 | 08:47 PM
sik96teg's Avatar
yea you can order the replacement cable from honda.
Here is the link to order
https://www.acuraoemparts.com/delray...All&vinsrch=no
Here is info on how to replace it. It doesnt have the pictures anymore but it will get you going
http://forums.g2ic.com/showthread.ph...t=speedo+cable
Old Apr 8, 2011 | 09:00 PM
you're awesome, thank you!
88EFsedan2
Feb 2, 2012 08:24 AM
G. Man
Classic Hondas
Jul 8, 2011 07:34 AM
josh760
Jul 24, 2010 09:31 PM
user 93082343
Mar 11, 2009 10:17 PM
crxblues
Dec 6, 2006 10:44 AM
