can you run....
Old Sep 9, 2003 | 11:08 AM
kHoA DoGG's Avatar
Default can you run....
Is it possible to have a kill switch and TT? Such as leaving the car running w/ the TT but shutting off all power to the car w/ the switch. This is because my ignition switch died and I don't want to replace it due to money woes...
Old Sep 9, 2003 | 01:00 PM
redlinegsr's Avatar
Default Re: can you run.... (sNoOziN' EF8)
there should be a way to wire it up...the ignition does basically the same thing. What happens is the turbo timer harness is placed before the ignition so when the ignition is turned off...tt takes over
6genocide6
Nov 28, 2024 03:30 AM
b005461
Aug 5, 2015 09:16 PM
SickWitIt2.0
Jan 22, 2005 11:27 AM
ckyguy
Oct 6, 2004 09:01 AM
