Can you get too cold of a spark plug?
Old Jun 24, 2003 | 09:57 AM
Smurfylude's Avatar
Default Can you get too cold of a spark plug?
Is it possible to get too cold of a plug? I'm turboing my Prelude and was shopping for plugs adn came up with this stupid quesion. So, is is poddible? And what would happen?
Old Jun 24, 2003 | 10:20 AM
romeo619romeo's Avatar
Default Re: Can you get too cold of a spark plug? (Sushi X [TCL])
to a point where it cant clean itself.. prolly at idle at most of the time....try to get ngk copper i forget the part numbers
Old Jun 24, 2003 | 12:37 PM
-Trinitron-'s Avatar
I would only go 1 stage colder unless you are running over 12 lbs of boost.
Old Jun 24, 2003 | 12:40 PM
b18bturbo's Avatar
Default Re: Can you get too cold of a spark plug? (SlowBlueSi)
wow from what i learned at the tuning seminar by ben strader yes you can actually get a too cold plug what happens is that it does burn correctly on the electrode strap. what you want is actually a colored rainbow color, on the strap too cold or too hot and too much retard and too much ignition advance will cause that rainbow color to move up and down.
Old Jun 24, 2003 | 12:47 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Can you get too cold of a spark plug? (b18bturbo)
so, your suggestion on plugs for 1 BAR plus would be.....
Old Jun 24, 2003 | 01:38 PM
Smurfylude's Avatar
so is 2 steps is too cold? Or is it ok? I'm looking to run 10psi ~12psi daily and 1 bar at the track
Old Jun 24, 2003 | 03:21 PM
madman604's Avatar
Default Re: (Sushi X [TCL])
sorry to hijack, but i'm running Bkr7E specs below. my plugs seem to foul rather quickly. should i use standard plugs?
Old Jun 24, 2003 | 04:03 PM
MiraiZ's Avatar
I'm using Apexi racing plugs #8...they are actually better than the NGK's I had. Unfortunately they cost $12 EACH
#7'spictured here
Old Jun 24, 2003 | 04:24 PM
Default Re: Can you get too cold of a spark plug? (MiraiZ)
heres my suggestions.. buy regular plugs for the street use and another set of sparkplugs for the track.. i suggest iridium for the track.. and 1 step colder for the street.. i mean the iridium plugs should last for a long time since its gonna be used only so often just down the track and back...after that just swap it out.. doest take long anyways just keep a wratchet and extention and socket for the plugs and your all set...
Old Jun 24, 2003 | 04:34 PM
scttydb411's Avatar
Default Re: Can you get too cold of a spark plug? (romeo619romeo)
i'm still running stock plugs/heat range. don't seem to have any probs at 8psi running 1/3 degree of retard per pound of boost. does this sound right?
Old Jun 24, 2003 | 09:29 PM
madman604's Avatar
Default Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">sorry to hijack, but i'm running Bkr7E specs below. my plugs seem to foul rather quickly. should i use standard plugs?</TD></TR></TABLE>
BTW which is colder BKR7E (shorter/recessed insulator) or 7FR5J-11 (longer/extended insulator)
Old Jun 24, 2003 | 11:02 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
On my 99 Civic Si, the BKR7E copper plugs were 1 step colder than stock. But I'm using some BKR7EIX-11's Iridiums which are 2 steps colder, which is way too expensive, and an overkill, so I'll be going to BKR7E.
Besides, I'm only pushing 5psi.
Old Jun 25, 2003 | 09:31 AM
madman604's Avatar
Default Re: (Snafu-Si)
bump
Old Jun 25, 2003 | 09:37 AM
VTC_CiViC's Avatar
I ran 2 steps colder on the Civic (stock was a 5-series, I ran BCPR7E's) and never had a problem with it... just my .02
Old Jun 25, 2003 | 10:11 AM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">I'm using Apexi racing plugs #8...they are actually better than the NGK's I had. Unfortunately they cost $12 EACH
#7'spictured here</TD></TR></TABLE>
Not to say they aren't good, but I'd wager they are made by NGK/Denso. I don't think there is any way that Apexi manufactures plugs.
Old Jun 25, 2003 | 10:13 AM
EE_Chris's Avatar
Article on Plugs
Might be of some interest to the current topic.
Old Jun 25, 2003 | 10:27 AM
mopar junkie's Avatar
FWIW the BKR7E and BKR7EIX-11 are the same heat range. The "7" indicates the heat range. Higher is colder. The "-11" signifies the pulg gap (-11 = 0.044" gap).
Old Jun 25, 2003 | 03:19 PM
madman604's Avatar
Default Re: Can you get too cold of a spark plug? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Article on Plugs
Might be of some interest to the current topic.</TD></TR></TABLE>
good stuff thanks
Old Jun 25, 2003 | 03:26 PM
MiraiZ's Avatar
Default Re: Can you get too cold of a spark plug? (ion_four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four &raquo;</TD></TR><TR><TD CLASS="quote">
Not to say they aren't good, but I'd wager they are made by NGK/Denso. I don't think there is any way that Apexi manufactures plugs.</TD></TR></TABLE>
you're probably right...they look suspiciously like NGK...I guess its just the lower heat range that makes my car run smoother...
Old Jun 25, 2003 | 03:33 PM
I Like Boost's Avatar
i run 1 bar daily and use ngk 8's. no problems
mugen94
Aug 19, 2009 04:22 PM
lacking vtec
May 20, 2007 11:37 AM
toooslow
May 14, 2003 11:37 AM
Adam.
Sep 14, 2002 02:00 PM
Casey
Mar 19, 2002 07:00 PM
