can we come up with the best solution for???
i'm so confused people say to hook up oil feed to the back of block, but it causes to much pressure and can blow the seals in the turbo.
then you got a guy who says plug it into the head at the vtec solenoid pressure check, but this location might not be enough psi of oil for the turbo
CAN WE COME UP WITH THE BEST SOLUTION?????
Ha Ha Ha, But I Need Boost, because my Brother has a 1g DSM with a Big 16g and I want to use his old Turbo 14d(i think) and Beat Him with Honda Power
SO i need all the help i can get!!!! thanks
so for my Ques?
so for my Ques?
Well, the SOLUTION is to put a F#$ing oil pressure gauge on your feed line and add a restrictor to drop the pressure feeding into the turbo.
