Can someone please confirm these thread sizes?
Old Apr 27, 2004 | 05:20 PM
Hoosier Daddy's Avatar
Default Can someone please confirm these thread sizes?
I have a Garrett t3/t04e, with a 4 bolt downpipe. I need studs/bolts to connect the downpipe to the turbo. I'd rather do studs and nuts. Is this the thread pitch I need for the studs? M8 x 1.25 If so, what size nut would fit that? Does the M8 mean 8mm? Isn't that a bit small?
Also, for the feed line, is the threading 1/8 NPT?
Just want to be sure before ordering...thanks
Old Apr 27, 2004 | 06:55 PM
Default Re: Can someone please confirm these thread sizes? (Hoosier Daddy)
Anyone?
Old Apr 27, 2004 | 07:34 PM
dfoxengr's Avatar
yes the feed is 1/8 NPT
and yes it should be 8x1.25 for the T-DP. M8 means 8mm, but i dont know about pitch. im rpretty sure M8 is 8x1.00
Old Apr 27, 2004 | 07:35 PM
AspectIndustries's Avatar
M8 x 1.25
Thats the size i used for my 5bolt t3to4e..
Old Apr 27, 2004 | 07:47 PM
Default Re: Can someone please confirm these thread sizes? (synik)
Thanks guys What about the 4 bolt?
Would these work?
8mm (1.25pitch) Stud
8mm (1.25pitch) Nut, Locking Head
http://www.atpturbo.com/Mercha...e=FST
Old Apr 27, 2004 | 08:11 PM
hpfsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys What about the 4 bolt?
Would these work?
Yep those are the ones...
Old Apr 27, 2004 | 08:35 PM
Default Re: Can someone please confirm these thread sizes? (hpfsi)
Thank you sir 8mm seems a bit small lol Time to order up.
Old Apr 28, 2004 | 01:12 AM
Flamenco-T's Avatar
8mm is the Diameter of the threaded part of the stud or bolt. 1.25mm is the distance between 2 threads.
The 4 bolt may use either 1/4" NPT or 1/8" NPT depending when your turbo cartridge was made.
The downpipe side can either be 8x1.25 mm( 95% of the time) or it could also be 5/16-14 bolts/studs as well.
Just take your turbo to the hardware store and find the right ones between the two I gave you above.
hope this helps, otherwise, IM or email me
stan
dizzyek
Nov 16, 2006 07:47 PM
dornon13
Jul 13, 2005 08:49 PM
Built B16A
Jun 30, 2004 07:58 AM
Teg4e
Mar 8, 2004 10:21 AM
ScrapinSi
Sep 24, 2003 08:39 AM
