Can i cut this intercooler down to size?
In theory it should work. As long as its completely ait-tight I can't think of any reasons why it wouldn't. But, check out the inside of your bumper, you might be able to make the bumper fit the intercooler.
Good Luck.
Good Luck.
Might become a pain in the *** project. The thing probably has leaks. After fixing a leak, you find another, and chase your tail trying to make it air tight.
Also... it's a tube-fin style which will be harder to cut and repair than a bar-plate. I personally don't feel tube-fin intercoolers are as good, either.
does anyone know what the max psi this can handle? and what if i cut it in half and put one behind the other and made new end caps? would that double the amount of boost it could handle because it would have 2 cores?
I was going to do the same thing, is that the standard Volvo intercooler, the only thing is it's really hard to seal plastic. I just ended up buying a Tyrus intercooler, so much nicer looking.
