Can this Block be saved?
Old Dec 18, 2012 | 09:08 PM
GEN2 LS's Avatar
Loved
Default Can this Block be saved?
upon pulling the head from my daily driver found this damage to the deck area and top of the sleeves. Motor is a b18a1, stock 81mm bore, just wondering if getting the block decked/ slight overbore to 81.5 or 82mm would clean it up?
I just hope the deck isn't screwed up beyond repair
Old Dec 18, 2012 | 09:47 PM
Muckman's Avatar
Moderator in Chief
Default Re: Can this Block be saved?
Yes you have options-
Sleeve it
Oring it
Or mill the crap out of it and run a thicker head gasket
Old Dec 18, 2012 | 10:00 PM
Khnemu's Avatar
Looks like someone dropped it down a gravel hill, lol.
I agree with what Muckman said.
Old Dec 18, 2012 | 10:22 PM
wantboost's Avatar
Who is Mr Robot?
Sleeving it would be your only option, damage is too deep to be milled away.
Old Dec 19, 2012 | 06:35 AM
kyden's Avatar
you'll have to resleeve. how did this happen? did you damage it when you removed the head? i can't see this happening on its own.
Old Dec 19, 2012 | 09:12 AM
heavy duty's Avatar
Just have around the out side of the sleeve tiged up and deck it down flat. It will be ok i have done this on a nos motor before. It held a 200 kit after just fine. It was also a 82mm.
Old Dec 19, 2012 | 12:23 PM
KevinEF7's Avatar
Cant be saved, scrap it.
Dont use thing to pry the head off next time
Old Dec 19, 2012 | 12:46 PM
wantboost's Avatar
Who is Mr Robot?
The damage is too deep to be decked.. you'd have to take probably 5+mm off the deck which makes the motor unusable, Forever....
Sleeve it or find another
Old Dec 19, 2012 | 01:07 PM
GEN2 LS's Avatar
Loved
Thanks ya'll looks like I get to use this b20 bare block I've had laying around now.
Old Dec 19, 2012 | 01:08 PM
wantboost's Avatar
Who is Mr Robot?
But if you want to ditch that block, I need one for mockup stuff
Old Dec 19, 2012 | 01:12 PM
gumby7_'s Avatar
i say ditch it. if u fix it and run into problems, would b worse.
Old Dec 19, 2012 | 01:13 PM
wantboost's Avatar
Who is Mr Robot?
Sleeving it would eliminate the problem but depending on his power goals would probably be pointless and a waste of funds that can go to other parts of his build
Old Dec 19, 2012 | 01:35 PM
GEN2 LS's Avatar
Loved
never intend to ever sleeve a motor, I would go with the CSS process before sleeving. my horsepower goals are modest by todays standards. I'm content with having between 350whp-475whp. Both of my previous cars where 400+whp one was a stock block high compression b16 on E85 and the other a built gsr on 93 octane. Anymore than 450whp isn't street friendly IMO or even fun to drive, spin, spin, spin, spin, spin... **** gets old.
Old Dec 19, 2012 | 01:38 PM
b00stman's Avatar
The only way to save it might be to weld it up and deck it back down but i would suggest doing a bore and hone after to be on the safe side.
For an LS block that are a dime a dozen id just pick up another. It would cost more to attempt to fix than it is worth.
Old Dec 19, 2012 | 01:41 PM
wantboost's Avatar
Who is Mr Robot?
I know exactly how you feel, my build has a torque goal, not a power goal... but I expect with my setup I can make the torque I want with 450hp or less.
really 350 is the limit for really good traction but 450 with boost by gear would be the limit. It's no fun driving a car on the street that just spins all the time
And you're right, for your goals sleeving isn't needed but I never considered the CSS process, might want to show them pics and see what they say. I've been debating about doing it on a spare block as well
Old Dec 19, 2012 | 08:35 PM
98lude-t's Avatar
CSS isn't the answer for this
Old Dec 19, 2012 | 08:44 PM
Spawne32's Avatar
shame you dont live closer, i have a fully assembled sb b18b1 id give you for 100 bucks
Old Dec 20, 2012 | 10:56 AM
GEN2 LS's Avatar
Loved
I believe you mis-read what I was saying. I know this block is useless at this point, other than getting sleeved. I was saying if I ever had to step up to sleeves for another motor I build I would opt over to CSS instead of AEBS Sleeves.
Old Dec 20, 2012 | 10:57 AM
GEN2 LS's Avatar
Loved
damn if only you did:/ well I found alot better alternative hopefully it can fall into my lap after Christmas!
Old Dec 20, 2012 | 01:13 PM
wantboost's Avatar
Who is Mr Robot?
Only if I did too... I need more motors as spares, I only have 3 ls motors lol
Old Dec 20, 2012 | 05:42 PM
SPOOLINmatt's Avatar
was it fine before removing the head? i know its beat up but **** can work like that
beginmyhonda
Jan 23, 2010 08:08 AM
nick91civicsi
Feb 2, 2008 08:56 AM
viet_boi_racin
Jun 10, 2007 01:17 PM
sivikvtec
Mar 16, 2007 10:47 AM
RACING INTEGRATION
May 22, 2006 03:31 PM
