Cams for a Non-Vtec Turbo setup?
Old Jul 15, 2003 | 12:35 PM
Teg4e's Avatar
Default Cams for a Non-Vtec Turbo setup?
I'm planning on upgrading with Hondata and partially or fully building my B18B. I'm wondering what you guys think I should do for the cams, considering i'm non-vtec. Should i stick with the LS cams, or upgrade to something different? my goals are something in the 300-350whp range.
Old Jul 15, 2003 | 03:38 PM
Loccster's Avatar
Default Re: Cams for a Non-Vtec Turbo setup? (Teg4e)
get crower 402 cams.
Old Jul 15, 2003 | 04:38 PM
Teg4e's Avatar
Default Re: Cams for a Non-Vtec Turbo setup? (BlazinTeg)
hmm...i just read a long thread of the regular users bashing crower cams... any more thougts on these? also, a local tuner, Howard of AR Fab, recommended Crane Stage 3 cams. What have you guys heard about these?
Old Jul 15, 2003 | 05:14 PM
Loccster's Avatar
crane's good too, saw a dyno in some mag and result came out pretty good.
Old Jul 15, 2003 | 05:28 PM
Kyoji's Avatar
Crane cams have been around for along long time. I know that the cams work great on v8's, but have no experience with their sport compact cams.
Old Jul 16, 2003 | 07:58 AM
Teg4e's Avatar
Default Re: Cams for a Non-Vtec Turbo setup? (Kyoji)
bump
Old Jul 16, 2003 | 08:07 AM
LSiTurbo's Avatar
crower 402T for LS. I mean... DAMN look at all that lift!!!!!
Old Jul 16, 2003 | 10:07 AM
CheezeFrog's Avatar
Default Re: Cams for a Non-Vtec Turbo setup? (LSiTurbo)
I run Crower 402T's. If you want to see how they perform, "right-click Save As" the link in my sig.
Old Jul 16, 2003 | 10:18 AM
Teg4e's Avatar
Default Re: Cams for a Non-Vtec Turbo setup? (CheezeFrog)
haha yes, i've seen the video; very impressive. but do you think it's unecessary/overkill for my more modest goals?
Old Jul 16, 2003 | 11:19 AM
MIKES's Avatar
For your goals the stock cams are more then enough. Spend that extra money on some head porting so it can breathe better up top where they usually flatten out because of the stock port configuration. Stock cams will make over 400whp easily if you got the right parts.
Old Jul 16, 2003 | 11:45 AM
Teg4e's Avatar
Default Re: Cams for a Non-Vtec Turbo setup? (MIKES)
my horsepower peaks in the 6-7k range, due to my 54 trim T3/t04 and also the LS head. So some head porting would help my flow up top? i'm thinkin about adding some springs/retainers, and putting redline up to 7.5k, if it's making the power up there to be worth it.
Old Jul 16, 2003 | 11:58 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">I run Crower 402T's. If you want to see how they perform, "right-click Save As" the link in my sig.</TD></TR></TABLE>
How much power do you think you picked up with the crowers? They look kinda weaksauce on paper with only 190 duration @ .050, but there's a lot of lift there so I guess it would work good without sacrificing drivability.
Old Jul 16, 2003 | 12:46 PM
psileepR's Avatar
New User
Default Re: Cams for a Non-Vtec Turbo setup? (boosted92)
You can talk to Rocket here on HT he is in the process of designing cams for D and B series motors.
http://www.ef-1.com
Fc_v8
Jul 26, 2010 03:15 AM
Mindgamez
Mid-Atlantic (Sales)
May 14, 2010 02:39 PM
dohc_profile
Dec 11, 2006 04:27 AM
1QWKGS
Jul 19, 2003 11:36 AM
FAST94GSR
Nov 12, 2001 07:38 PM
