Cammed b18c - 6262 Finally!
Old Dec 4, 2011 | 10:22 AM
B00st3d-dc2's Avatar
Default Cammed b18c - 6262 Finally!
Ok, so I've finally got my setup almost 100%
B18C stock sleeve - cp pistons, manley rods
B16 head mild port - supertech valvesprings, retainers, valves
Skunk2 Tuner 2s
AEM cam gears
VictorX manifold
70mm Omni TB
6262sp .82 a/r
ID1000
walbro 255lph
Looking for 550whp
For those of you with similar setups, where did you end up with the gears? I'm aware it's not an exact science just looking to get an idea so I can save time on the dyno.
Similar to NA, i.e. intake ahead of exhaust?
Also, anyone running the 400lph walbros? Can I run stock feed/return lines with the 400lph or do I need to upgrade for my 550whp goal?
Old Dec 4, 2011 | 06:36 PM
imptricer's Avatar
Default Re: Cammed b18c - 6262 Finally!
stock lines some guys switch the the return to the feed but just for reassurance for 550 stock lines
Old Dec 4, 2011 | 07:12 PM
LocoJoe's Avatar
I did 600 on stock lines, walbro 255, ID1000s and a good return line.
Nothing to do with your question but 550whp on a stock sleeve is playing with fire.
Old Dec 4, 2011 | 07:24 PM
Thanks. There's a method to the madness - 550whp is a goal, I'll see what's possible/safe when I get it on the dyno.
Old Dec 6, 2011 | 06:14 AM
bump to the top...
noone has rocked gears on a similar setup?
Old Dec 6, 2011 | 07:26 AM
m3tech95's Avatar
i swapped out my feed and return lines for -6an not because i needed to, but because i wanted to run the stock motor until i couldnt anymore and put a built motor in and not have to go through that process later...your going to want more horsepower after your done its been said time and time again...you dont want your car to be limited.....
A wise man once told me "Motors will blow if the fuel doesnt flow"
Old Dec 6, 2011 | 01:27 PM
d16z6Tcrx's Avatar
i made 550 on 21 psi stock sleeve 6262 and i drive it everyday. stock lines and a 255lph.
only thing i was on type r cams and a .63 a/r.
Old Dec 6, 2011 | 08:02 PM
2000CTRSi's Avatar
Leave the gears zero'd out till the final tune and then figure out which way you want to shift the powerband.
paulzy
Mar 17, 2009 09:34 PM
96 GSR-T
Oct 19, 2007 11:28 AM
96 GSR-T
Oct 11, 2007 12:23 PM
Targa4Life
Apr 3, 2007 11:50 AM
SIReg9
Sep 29, 2003 04:51 AM
