Camgears w/Turbo?
Re: Camgears w/Turbo? (WykidEG6)
I run a str cam gear. Dont know if its good as of right now its pointless because I have nothing tuned on my car. Aem/Str I guess are good.
I was wondering if i should get cam gears before i get on the dyno myself. I dont think i would buy the aem, i just dont like the idea of only 3 bolts being there to save my motor from blowing up. I would get something like a Skunk2 or hayame or something to that kind of quality
Re: Camgears w/Turbo? (dlplayboy)
Skunk2 all theway! I have it, I love it, no problems!
The laser printed points are a bit off, but you should measure the exact zero/zero setting with an special tool, donßt know the name of this tool.
Re: Camgears w/Turbo? (austrian type-R)
Re: Camgears w/Turbo? (CRXRageD)
I run Jun also, they will never slip and have best tolerance of any gear as they are not machined, they are remaned stock cam gears.
Re: Camgears w/Turbo? (B20LS-T)
Endyn makes some damn fine cam gears IMO, I remember seeing them before they hit the market. I dont know about you, but I love the fact that it's multiple keyway for zeroing purposes. that means you can shave away for some extra compression. Then again, thats if you are NA. you may not wanna do that if you are FI, but still a damn fine design. I know Endyn probably pissed off AEM, Unorthodox and all the other cam gear manufacturer's. They built my engine, so I know firsthand, they rule.
Re: Camgears w/Turbo? (TurboSohc)
I have these on my GSR turbo... as light as the Skunk2 ... We sell them for 239 bucks a pair... very cheap, wery strong, and very light ... ALD
[Modified by meanteg, 2:32 AM 4/25/2002]
I think they all do the same ****. When it comes to cam gears cheaper=better atleast to me
Re: Camgears w/Turbo? (ek9t)
cheaping out is why things break... remember that
Re: Camgears w/Turbo? (downpipe)
here is an interesting read i stumbled across for CAMS not camgears:
http://jdmfan.com/articles/itr-cams_analyzed/
New User
Re: Camgears w/Turbo? (civicefhatchback)
HKS cam gears... they're high dollar, but they screw into STEEL, no aluminum, and I've seen them on 1100 HP supras, not having issues
