Cam trigger mount
Old Mar 6, 2005 | 11:46 PM
  #26
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Cam trigger mount (tony1)
hmmm ive been thinking about this..i might have to contact ya...looks good
Old Mar 7, 2005 | 10:20 AM
  #27
ComposiMo's Avatar
Default Re: Cam trigger mount (bruceleeroy)
Here is a bracket that i made for 'someones' car here in the shop for the Norwood sensor kit... lol
Old Mar 7, 2005 | 10:32 AM
  #28
DIRep972's Avatar
Smarter than you
OMG!!! BEST BRACKET EVAR ALERT!!!!! SO CLEAN I COULD EAT OFF IT!!!!!
but really.... stop making it look so pretty, we just need the car to run. looks very nice.
Old Mar 7, 2005 | 10:54 AM
  #29
Soon_2b_evil's Avatar
Default Re: Cam trigger mount (DIRep972)
will this work with any kinda cam gears?
Old Mar 7, 2005 | 12:23 PM
  #30
PrettyLude's Avatar
if i remember correctly tony said only GE cam gears
Old Mar 7, 2005 | 01:31 PM
  #31
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Cam trigger mount (ComposiMo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComposiMo &raquo;</TD></TR><TR><TD CLASS="quote">Here is a bracket that i made for 'someones' car here in the shop for the Norwood sensor kit... lol
Does this 'someone' have the Autronic CDI too?
Old Mar 7, 2005 | 02:01 PM
  #32
lbz34's Avatar
Default Re: Cam trigger mount (Arturbo)
My bracket is off the intake side. How much for one?
I also have Bob's kit.
Modified by lbz34 at 5:18 PM 3/7/2005
Old Mar 7, 2005 | 04:13 PM
  #33
ComposiMo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Does this 'someone' have the Autronic CDI too?</TD></TR></TABLE>
I do believe so...
Old Mar 7, 2005 | 06:01 PM
  #34
tony1's Avatar
Default Re: Cam trigger mount (lbz34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lbz34 &raquo;</TD></TR><TR><TD CLASS="quote">My bracket is off the intake side. How much for one?
Modified by lbz34 at 5:18 PM 3/7/2005</TD></TR></TABLE>
If it's on a b series, then there's only one 10mm hole there to attach to. I won't do a bracket with only one bolt, cause it can pivot if there's only one bolt. It would be a fairly complex bracket to do it right because it would have to pick up another point and there's nothing convenient to pick up from over there. The gears are the same, move it to the exhaust gear and do the bracket like these.
On the gears, Golden Eagle are the only ones i've found that are thick enough on the outer ring to install the magnets.
Old Mar 7, 2005 | 06:19 PM
  #35
sporkcrx's Avatar
Default Re: Cam trigger mount (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Your work is just retarded! </TD></TR></TABLE>
That's what I was going to say too after seeing all those pics. Absolutely amazing. I don't know about everyone else, but it sure as hell encourages me to work harder.
Old Mar 7, 2005 | 07:00 PM
  #36
st00pid's Avatar
Default Re: Cam trigger mount (sporkcrx)
awesome work as usual.
Old Mar 7, 2005 | 07:46 PM
  #37
Danger's Avatar
Default Re: Cam trigger mount (st00pid)
damn you do some amazing work !
Old Mar 7, 2005 | 09:35 PM
  #38
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Cam trigger mount (JonnnyDanger)
Tony think you can make it a little bit lighter?
Old Mar 7, 2005 | 09:38 PM
  #39
HRTuning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Tony think you can make it a little bit lighter? </TD></TR></TABLE>
haha
Old Mar 7, 2005 | 10:01 PM
  #40
SOHC_MShue's Avatar
damn ingenious
Old Mar 8, 2005 | 12:51 AM
  #41
gldndrgn14's Avatar
Default Re: Cam trigger mount (SOHC_MShue)
is neptune planning on making their system compatible with the direct ignition setup?
Old Mar 10, 2005 | 02:12 PM
  #42
gldndrgn14's Avatar
Default Re: Cam trigger mount (gldndrgn14)
bump for my question on dis for neptune.
Old Mar 10, 2005 | 02:21 PM
  #43
espanol's Avatar
who's tony1? he's dreamy!!!
Old Mar 10, 2005 | 03:32 PM
  #44
gldndrgn14's Avatar
Default Re: Cam trigger mount (espanol)
-Individual cylinder ignition trim...
taken from hrtuning neptune's features list.
http://hrtuning.com/index.php?page=neptunefeatures
so shouldnt that mean its compatible with direct fire ignition?
Old Mar 10, 2005 | 11:38 PM
  #45
Arturbo's Avatar
Better than steak
25 Year Member
I think you would need to run an ignition expander to run individual coils?
Old Mar 11, 2005 | 12:07 AM
  #46
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you could, but for full sequential operation you'd still have to use a cam trigger too. This does both, cam and crank trigger in one. Another plus is that it's a hall sensor, which has an 8v square wave output. The oem honda sensors are magnetic and have low voltage sine wave signal that's very succeptable to RF noise. All in all, the square wave is a much cleaner signal.</TD></TR></TABLE>
I feel so dumb thats what I was thinking about awhile back in that other thread you made. I was thinking about the oem magnetic sensor.
My fault.
Old Mar 11, 2005 | 04:45 AM
  #47
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I think you would need to run an ignition expander to run individual coils?</TD></TR></TABLE>
The ignition expander is a motec part and will only work with motec.
Old Mar 11, 2005 | 04:50 AM
  #48
Arturbo's Avatar
Better than steak
25 Year Member
How can you run 4 coils with 1 ignition output?
Old Mar 11, 2005 | 04:54 AM
  #49
tony1's Avatar
Only with Motec as far as i know. In the motec ignition configuration, there's the option for the expander. You tell it how many coils you are using, and run your one ignion output into it, and it counts from there. Ahh, the wonderfull things you can do with motec...that you can't do with brand "A"...
Old Mar 11, 2005 | 05:08 AM
  #50
Arturbo's Avatar
Better than steak
25 Year Member
At least that "A" has 4 ignition outputs and you dont need to run an expander.
