Cam trigger mount
Old Mar 6, 2005 | 03:36 PM
tony1's Avatar
Default Cam trigger mount
I have had alot of questions about the cam trigger setup we offer to get rid of the distributor. Here is the bracket that holds the sensor that I made for Arturbo's car. I'm looking into getting some more cnc'd, but for now they're one offs. For anyone interested in the trigger setup, it'll work with most aftermarket ecu's with configuarable trigger modes. It uses 13 magnets on the cam gear. 12 are evenly spaced have the same pole facing out and 1 is placed in between 2 of the others with the opposite pole facing out. The sensor is a dual pole hall sensor, it triggers two different wires according to magnetic poles. You will configure your ecu to see 6 crank triggers per engine revolution and the cam trigger will come once per rev. The number of magnets may differ with different systems, I know on Art's autronic it needs 5 total, 4 for crank and 1 for cam. Remeber, since the crank trigger signals are coming from the cam, you only get half the pulses for the magnets you have, since it spins at half engine speed.
I haven't mounted the sensor in these pics yet, i'm waiting for some more magnets to come in. The sensor has to be in a pretty exact location since the magnets must pass across the middle of the sensor. The magnets are installed directly into the cam gear facing outward and the sensor will thread into the bracket facing the cam gear.
Old Mar 6, 2005 | 03:44 PM
Kwuaymaikrup's Avatar
Default Re: Cam trigger mount (tony1)
Wow...looks really nice. If I ever upgrade standalones I will be giving you a call. What do you charge BTW?
Old Mar 6, 2005 | 03:47 PM
tony1's Avatar
Default Re: Cam trigger mount (Kwuaymaikrup)
The target price is $550 with the bracket and everything, but that depends on the cost of the bracket. The kit ready to go without the bracket is $450.
Old Mar 6, 2005 | 03:52 PM
Bulldogg83's Avatar
Looks good.
Old Mar 6, 2005 | 04:33 PM
azfab1031's Avatar
Default Re: Cam trigger mount (Bulldogg83)
Looks really good .
Here is the one I made for our car awhile back.
Old Mar 6, 2005 | 04:46 PM
SEFIxCivic's Avatar
makes my welded bracket look like crap
Old Mar 6, 2005 | 05:23 PM
Blown90hatcH's Avatar
Default Re: Cam trigger mount (SEFIxCivic)
Lighten that sucker up! Mill those pockets out! Looks good tony.
Old Mar 6, 2005 | 05:28 PM
tony1's Avatar
Default Re: Cam trigger mount (Blown90hatcH)
Vibration on this part would be bad!! I could go little lighter, but I like the way it looks and while we are watching the weight with this car, we're not looking at it in grams yet. lol
Old Mar 6, 2005 | 05:32 PM
D-tuned's Avatar
looks real good
Old Mar 6, 2005 | 05:47 PM
DaveF's Avatar
Default Re: Cam trigger mount (2000civicsi)
i could use a bracket
Old Mar 6, 2005 | 06:12 PM
sporkcrx's Avatar
Default Re: Cam trigger mount (Dturbocivic)
How are the magnets held onto the cam gear? I've never seen this before, pretty crazy.
Old Mar 6, 2005 | 06:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Vibration on this part would be bad!! I could go little lighter, but I like the way it looks and while we are watching the weight with this car, we're not looking at it in grams yet. lol</TD></TR></TABLE>
Busting you tony. IT looks good man. 6061?
Old Mar 6, 2005 | 06:51 PM
LSVtechnologytur...'s Avatar
any pic's of the whole set up installed in a car?
Old Mar 6, 2005 | 07:23 PM
tony1's Avatar
Default Re: Cam trigger mount (vtec'n)
I've done it a few different ways in the past...
Old Mar 6, 2005 | 07:26 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
Busting you tony. IT looks good man. 6061? </TD></TR></TABLE>
Yes, 6061.
Modified by tony1 at 10:46 PM 7/18/2005
Old Mar 6, 2005 | 07:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
More bling for my car. thanks tony.
Old Mar 6, 2005 | 07:56 PM
Motorhead_AZ's Avatar
Default Re: Cam trigger mount (Arturbo)
Can't you use an OBDII crank angle sensor instead??
Good fab work
Old Mar 6, 2005 | 08:00 PM
tony1's Avatar
Default Re: Cam trigger mount (Motorhead_AZ)
Yes, you could, but for full sequential operation you'd still have to use a cam trigger too. This does both, cam and crank trigger in one. Another plus is that it's a hall sensor, which has an 8v square wave output. The oem honda sensors are magnetic and have low voltage sine wave signal that's very succeptable to RF noise. All in all, the square wave is a much cleaner signal.
Old Mar 6, 2005 | 08:21 PM
FredoSP's Avatar
Tony,
Hall Effect sensor? They detect a magnetic field, right?
Old Mar 6, 2005 | 08:24 PM
PrettyLude's Avatar
lookin good tony
Old Mar 6, 2005 | 08:48 PM
tony1's Avatar
Default Re: Cam trigger mount (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">Tony,
Hall Effect sensor? They detect a magnetic field, right?</TD></TR></TABLE>
Some do, some detect something magnetic like steel. All hall sensors have a square wave output though.
Old Mar 6, 2005 | 08:51 PM
Your work is just retarded!
Old Mar 6, 2005 | 08:53 PM
tony1's Avatar
Thanks
I'll be inspecting your work when I recieve my harness!! You better be on your best behavior!
Old Mar 6, 2005 | 09:20 PM
mrDFWmechanic's Avatar
another reason why i'm glad i'm glad that i'm close by to tony
Old Mar 6, 2005 | 10:30 PM
*Boostwerks*'s Avatar
Wow.
I'm always amazed by your fab work tony. Great stuff.
I'm sure a lot of teams would not be where they are today with out the work you've done.
