cam shaft installation
Old Jul 30, 2003 | 09:56 AM
InTeGrA B18b1's Avatar
Default cam shaft installation
i recently pulled the head off for a blown head gasket...
and im not sure how to put the cam shaft back on.. i know if im off by alil my timing will be all wak and blow sumthing else...
i think u just put the piston at tdc and also the cam shaft... i just want to make sure if im right
Old Jul 30, 2003 | 09:57 AM
Default Re: cam shaft installation (InTeGrA B18b1)
bump
Old Jul 30, 2003 | 10:04 AM
toolowsol's Avatar
set the crank to TDC (there is a mark by the crank pulley also) then set both cam shafts (or one if you have sohc) to tdc as well, retention the belt, tighten the tentioner and your done.
ohsnapzafingcu
Sep 7, 2006 01:03 PM
Muckman
Sep 22, 2004 09:44 AM
donnjuan2point2
Mar 4, 2004 04:40 PM
DC2R714
Oct 28, 2002 02:12 PM
