Cam Gears settings with a turbo???
Old Oct 7, 2004 | 04:12 PM
jsprelude's Avatar
Default Cam Gears settings with a turbo???
I have skunk2 cam gears on my greddy turboed prelude. when i had the car tuned with the hondata they didnt mess with the cam gears. The are both set at zero. Any of you guys running a turbo have your cam gears adjusted any particular way other that zero?? Just curious??
Old Oct 7, 2004 | 04:19 PM
Rob Dizzle's Avatar
Default Re: Cam Gears settings with a turbo??? (jsprelude)
you have stock cams I would guess?
usually with cam gears you are shifting power to different parts of the power band. unless you arent making power at a certain rpm range. you might be able to just put your stock ones back on and call it a day
Old Oct 7, 2004 | 05:48 PM
RyanEJ8's Avatar
Only way to really find out the best cam gear settings is on a dyno. Generally, retarding shifts the powerband higher and advancing shifts it lower.
2kdrift
Mar 15, 2016 02:32 PM
civic_saints1
Jun 15, 2007 03:08 PM
f22abuilder
Feb 16, 2006 06:10 AM
Sir-Boost-Alot
Oct 26, 2005 02:00 PM
