cam gear settings
Old Apr 3, 2003 | 01:54 AM
Zero2Sixty's Avatar
Default cam gear settings
Whats a decent cam gear settings for a b20 block, with a b16 head, and gsr cams on a turbo ride boosting about 10 psi? And I know I should just dyno it to find a good hp setting but looking for something good to start off at.
info on this is greatly appreciated.
thanks
Old Apr 3, 2003 | 02:11 AM
ninesecrx's Avatar
Default Re: cam gear settings (Zero2Sixty)
Stock...
Old Apr 3, 2003 | 06:28 AM
*Boostwerks*'s Avatar
Default Re: cam gear settings (ninesecrx)
Stock...
Would there be any situation with Honda motor's where you would recommend something other than stock?
Old Apr 3, 2003 | 08:45 AM
Farnsrocket's Avatar
Default Re: cam gear settings (Bryson)
I have not been able to find anything on this, plus Search is disabled (edit: it's back up now, still can't find anything though)
I had my head milled .030" ...........how will (or will it) that effect my cam gear settings?????
[Modified by Farnsrocket, 9:46 AM 4/3/2003]
Old Apr 3, 2003 | 12:57 PM
Default Re: cam gear settings (Farnsrocket)
I do know that milling the head will affect the cam timing. I do not however, know whether or not they need to be advanced or retarded.
I'm kinda wondering if a fully built honda motor would benefit from cam gears? would the money spent be worth it performance wise or just for cosmetics?
Old Apr 7, 2003 | 06:02 AM
Cool, thanks! Anybody have an idea of which way I should begin advancing or retarding them?
bigsnorlax
Apr 20, 2009 09:18 AM
Po0r LiTTle CoUpe
Aug 3, 2006 08:16 PM
Gojira D.O.T
Feb 25, 2006 02:34 AM
ityab0y
Feb 15, 2005 07:09 AM
CANTFAZZDISCHIT
Apr 4, 2004 07:16 AM
