c.r. and piston question?
Old Dec 8, 2003 | 01:46 PM
streetlvlhatch's Avatar
Default c.r. and piston question?
I have a b18b block with srp 8.5:1 compression pistons. I just decided to put my vtec head on. I was wondering what compression it will be with a gsr head and stock headgasket. Also, will the valve relief on these pistons be o.k.?
Old Dec 8, 2003 | 03:36 PM
boostlee's Avatar
Default Re: c.r. and piston question? (streetlvlhatch)
do more research. when you put on the vtec head, its might raise the compression ratio. you need to make sure the valves will not touch the top of the piston. alot of research need imo.
good luck
http://www.cardomain.com/id/boostlee
Old Dec 8, 2003 | 04:08 PM
Default Re: c.r. and piston question? (boostlee)
i was thinking that my cr would be around 9:1 and just wanted to see if anyone had a similar setup. I really need help with the valve relief!
Old Dec 8, 2003 | 06:18 PM
HELP!
johnzm
Mar 11, 2005 04:19 PM
yellowmonkeyboy
Oct 1, 2004 03:38 PM
done
Sep 7, 2004 09:57 AM
IMSTOCK
Jan 14, 2003 03:04 PM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
