A/C power loss with new engine
Old Aug 2, 2002 | 05:10 PM
GruvyTune's Avatar
New User
Default A/C power loss with new engine
please help.
I have 9:1 pistons now and I find that with the ac on i get a definite power loss compared to when i was a stock engine. car pulls fine once it gets going but the load definitely seems higher than before. and when i come to a stop the car idles down really low (even stalled a couple of times) and then comes back up to normal steady idle.
Old Aug 2, 2002 | 05:55 PM
AB16A2T's Avatar
Default Re: A/C power loss with new engine (GruvyTune)
You have two things that create drag, one is A/C one is Turbo. Turbo is backpressure you have to overcome and A/C is parasitic drag. Going to have more power loss compared to stock when you have two things creating powerloss until you come into boost (for turbo).
Old Aug 2, 2002 | 06:52 PM
Smashback's Avatar
Default Re: A/C power loss with new engine (Ares81883)
Haha yeah my turbo really slows me down until boost kicks in. Do you have a turbo? If so there maybe something wrong with it because my car is faster from 1 RPM all the way to 7000 RPM with the turbo as opposed to before!
Old Aug 2, 2002 | 06:58 PM
DragII's Avatar
25 Year Member
reason 84 why not to lower compression when going turbo. nice and safe...but nice and slow when your not under boost.
Old Aug 2, 2002 | 07:33 PM
93LSivic's Avatar
Can somebody please explain to me what "A/C" is??
Old Aug 2, 2002 | 08:03 PM
W.Zero's Avatar
Default Re: A/C power loss with new engine (93LSivic)
what is a/c cause i live in s. cali in the valley where you would need a/c but not for a race car. your a/c is turning another pulley which means power loss but if your a turbo car you want to take out you a/c for the weight and one less pulley to turn.
Old Aug 2, 2002 | 08:20 PM
Extent's Avatar
Air Conditioning :D but it's bad because cold air is heaver so when you run it your car gains weight
Wouldn't getting an underdrive pully help w/ this? I'm just totally guessing here but that drives the accesories less and so frees up that HP for the engine
[Modified by Extent, 9:21 PM 8/2/2002]
Old Aug 2, 2002 | 08:45 PM
W.Zero's Avatar
Default Re: A/C power loss with new engine (Extent)
the pulleys are just light in weight but the a/c on will still lose power. a/c and turbo dont mix.
Old Aug 2, 2002 | 09:49 PM
rjardy's Avatar
Default Re: A/C power loss with new engine (W.ZeroB18C1T)
Move to Texas and say that
Rob
Old Aug 3, 2002 | 06:56 AM
E Swift's Avatar
Default Re: A/C power loss with new engine (rjardy)
Even up here in Wisconsin during the summers will suck for a turbo. Its been like almost 100 degrees with high humidity for the past month or so. I can't live without my A/C,
Old Aug 3, 2002 | 07:48 AM
M.A.R.C.'s Avatar
Default Re: A/C power loss with new engine (E Swift)
yup... same here in FL. I won't be pushing the car hard at all during the daytime... too damn hot n humid
mykulangot92
Mar 29, 2010 03:38 AM
jaM3s Bond
11
Aug 6, 2003 11:39 AM
krings
May 9, 2003 01:26 AM
shamoo
Sep 11, 2001 05:31 PM
JSpecwest
Jul 30, 2001 12:01 AM
