Buzz at ~40mph+
Old Jan 11, 2003 | 06:04 PM
echo999's Avatar
New User
Default Buzz at ~40mph+
Ok, I just changed out my axles with DSS Stage 1 axles, which I thought
would have fixed the buzzing sound I have.
It didn't fix it. Now I'm thinking that it is something else. It makes it regardless
if I have load on the tranny or not at ~40+ mph. Really loud.. It kinda sounds
like a flapping piece of plastic buzzing from wind. (kinda like a reed from a musical
instrument).
Does exhaust leaks sound like this?
Old Jan 11, 2003 | 07:40 PM
LS-hatch's Avatar
Default Re: Buzz at ~40mph+ (echo999)
mabey a loose bolt rattling
Old Jan 11, 2003 | 07:54 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Buzz at ~40mph+ (LS-hatch)
thats sounds wired man. How do you know that its the axles? Maybe time for a tranny rebuild.
Blaze
Old Jan 11, 2003 | 07:57 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Buzz at ~40mph+ (Blaze45)
could it be your antenna? mine makes a certian noise right around there and it bugs... your exhaust leak would sound like air blowing thats under pressure.
rev your car w/ the passenger side door open and you should hear it if thats the problem.
Good Luck w/ this one!
Blaze
Old Jan 19, 2003 | 07:58 PM
NightmareApex's Avatar
Yeah I had a bolt on the gravel catcher under the car that would flap over 40+, One question though does it do it in neutral? Also check ur disk brake covers they might be bent or somethn.
Old Jan 20, 2003 | 03:40 AM
echo999's Avatar
New User
Default Re: Buzz at ~40mph+ (NightmareApex)
Gravel Catcher?
My disk brake covers are bent.. does it really make this sound?
It doesn't do it in idle...
Old Jan 29, 2003 | 02:53 PM
echo999's Avatar
New User
ix3mydc
Sep 13, 2008 03:32 PM
dc4teg95
May 15, 2007 10:24 PM
HECTIC
Sep 23, 2005 08:53 AM
InLimbo87
Jul 28, 2004 04:31 PM
Sketch_hs
25
Jul 27, 2003 02:06 PM
