Buying New Distributor?
Old Jan 30, 2009 | 10:59 AM
PhantomX's Avatar
Default Buying New Distributor?
Ok so I think I found my problem with my car, I'm pretty sure my distributor is going bad so I've been looking around to buy a new one or a used one to replace mine...I found a good deal for a OEM Distributor setup for an external coil with a Crane Cams distributor cap w/MSD wires.....
My question is "Will it work fine if i just install everything except the external Coil?" since the deal doesn't come with a Blaster coil......
Old Jan 30, 2009 | 11:47 AM
importdude2000's Avatar
Default Re: Buying New Distributor?
swap your stock coils back in if it got removed
reinstall factory wiring for coil
and use stock cap with internal coil and your good
Old Jan 30, 2009 | 01:15 PM
PhantomX's Avatar
Just to make sure.... So I buy the new distributor... take off the crane cams cap and use my original stock one with internal coil (basically swap the caps and everything inside) ?
My bad... I never done this before, i don't want to mess my sh*t up even more haha
Old Jan 30, 2009 | 01:40 PM
yes
some ppl remove coil inside some ppl leave it there
when u remove the cap u will see 2 screws
and wire
get a helms and wire as it spose to be then put it back in
not hard at all i did it 3 times b/c i changed cars
my original install
removed to put on new car
and removed to sell
Old Jan 30, 2009 | 02:23 PM
PhantomX's Avatar
Oh kool thanks for the tip
Quade
Mar 14, 2008 09:47 AM
joncowden
Mar 11, 2008 06:14 AM
prjctwhteg
Nov 10, 2006 04:36 PM
d16rice
12
Apr 3, 2005 06:09 PM
dyg2001
Feb 24, 2004 09:38 AM
