Building up my b18c1
Currently im running a boosted stock block and head at 10psi with a garrett t3/t4 hybrid turbocharger.
This is the setup I have in mind on building this winter.
B18c1 84x89 with darton sleeves
Eagle forged LS connecting rods
LS Wiseco 9/1 compression forged pistons
Mircopolished Oem LS Crankshaft
Moroso Oil Pan
Oem main and rod bearings
Arp main and head studs
Endyne oil pump
Oem water pump
All new gaskets and seals
B18c1 Gsr head
Skunk 2 Stage 2 pro series camshafts
Bisimoto Cam Gears
Supertech dual valve springs and titanium retainers
Edelbrock Victor x intake manifold
Skunk 2 68mm throttle body
Y80 gsr Jasper racing Transmisson with Lsd and racing syns
Exedy stage 2 three puck clutch which I already have
Well thats whats in the works. Im trying to max out my turbo, then next summer upgrade to a larger one.
What do you guys think of the setup? good or bad?
Moroso Oil Pan
Endyne oil pump
Oem water pump
B18c1 Gsr head
Bisimoto Cam Gears
Re: Building up my b18c1 (almostboostedgsr)
Thats a lot of money to drop in an engine without matching it with a the proper turbocharger NOW.
Whats your turbo kit specs?
Moderator
Re: Building up my b18c1 (JoePSI)
what are you trying to do with the car? What's your goal? Power? Purpose? You have a similar setup to what i've helped many people with, but you need to let us know that you're trying to do with the car before even getting a larger turbo...
C'mon man. be specific. You've done well so far, don't be lazy
Re: Building up my b18c1 (TheShodan)
Im trying to make the car a pro am drag car. Im shooting for a mid to low 10second pass in a half interior integra gsr. Hp goal is around 575-615. My turbo on there right now max's out at 475whp and is a t3to4e 57trim.
The turbo I have in mind of upgrading to is either a gt35r or a gt40r.
Moderator
Never go by an E.T. to determine the turbo you need. Most of that decision is going to be on your driving skills. The car and parts are just a tool to get to that goal.
You could do that, or check out the S366 (good to almost 800whp), or the S372( over 900whp.)Either of those make more power than a GT35R (about the same as a GT40R,) and under 1500 bucks, that is rebuildable in case something happens. You know the old saying, "if it ain't breakin', you ain't racing"...
Now since I last posted I switched a few things. Im going to go with manley turbo tuff rods because they are alot stronger than the eagles. Im going to go with an 83mm sleeved block and JE 9:1/ forged pistons.
I already purchased the rods and pistons.
Now I have a few questions. Will a stock b18c1 cylinder head exceed 600whp with cams,supertech valvetrain or should I invest in a three angle valvejob.
Is the s366 a borgwarner turbocharger?
Thanks thus far.
Thanks thus far.
xotic_crx
17
10-28-2014 04:00 AM
