Building A Head for Nitrous
Old Sep 3, 2005 | 12:16 PM
JaymieTypeR's Avatar
Default Building A Head for Nitrous
ok my block is being built up right now and im still deciding if i should touch the head.
i have a stock type r head and im going to be spraying around 100-130hp worth of nitrous on the motor. i was wondering if it should put in forged valves, and titanium valve springs and retainers for that much nitrous.
or would the stock type r stuff hold up with no problems
thanks for any help
Old Sep 3, 2005 | 12:33 PM
N20civicB18's Avatar
Default Re: Building A Head for Nitrous (JaymieTypeR)
SS valves would deffinitally be a well worth it part when using alot of nitrous. springs and retainers well I would do them too if you have the money but typee-r stuff is a little stronger then other motors so better then stock b16/gsr's i guess
Old Sep 3, 2005 | 01:17 PM
99_GS-T's Avatar
Might be worth porting the exhaust side and getting larger exhaust valves. Nitrous motors have a lot more exhaust volume.
Old Sep 3, 2005 | 01:23 PM
2k.civic.si's Avatar
Default Re: (99_GS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">Might be worth porting the exhaust side and getting larger exhaust valves. Nitrous motors have a lot more exhaust volume.</TD></TR></TABLE>
wise words
Old Sep 3, 2005 | 04:32 PM
Default Re: (2k.civic.si)
i was thinking about getting a whole buddy club package with springs, retainers, valves and the spec 4 cams.
but i wasnt sure how the nitrous would go with those cams
Old Sep 4, 2005 | 06:18 PM
Default Re: (JaymieTypeR)
Old Sep 4, 2005 | 07:17 PM
SOHCmaster's Avatar
Get some Manley race valves for sure, the valves get eaten up bad from nitrous hits.. You might wanna work the head for better quench as well while its off if you know how to do this.
If I were running that big of shot I would weld in tighter Quench spots and CC the heads for tighter #s and not risk hot spots to melt ****.
Old Sep 4, 2005 | 07:41 PM
HEAD's Avatar
Default Re: (PK SPEED)
I second the valve idea, I wouldn't trust anything stock...as far as porting, you can port the head for NOS but when your not on the button it will run like a dog with fleas. I would buy the super comp valves from ferrea at least for the exhaust side.
IntegraGuy04
Jan 28, 2007 10:01 AM
CIVICLUDE
Jun 11, 2005 06:44 PM
integranator
Dec 10, 2003 10:28 PM
Cashflo
Dec 3, 2003 12:38 PM
H23 Power
Apr 21, 2003 09:58 AM
