Building gsr need input
Old Jul 31, 2011 | 03:27 PM
SloHa+ch's Avatar
Default Building gsr need input
hey guys im gonna be building a gsr over winter so far this is parts im thinking
60 trim garret .48ar-got already-might upgrade later any suggestions?
Cometic Headgasket Honda Acura Integra GSR
Cometic Complete Bottom End Gasket Kit Integra
Cometic Complete Top End Gasket Kit
ACL Race Bearings
ARP Headstuds + main
Wiseco Pistons-RINGS, WRIST PINS, AND LOCKS!
Eagle Rods- ARP ROD BOLTS
Darton MID Wet Sleeves
Brian Crower Stage 2 Turbo Cams
Brian Crower Valvesprings & Retainers
Brian Crower Stainless Steel Valves
AEM Tru-Time Adjustable Cam Gears
Skunk2 Pro Series Intake Manifold
Skunk2 Pro Series Throttle Body Integra
Anything im missing?
Anything diffrent im still unsure about cams
Old Jul 31, 2011 | 04:08 PM
Hidenplanvew's Avatar
Default Re: Building gsr need input
60 trim garret .48ar-Have already-Preciaion PT6262 would be a nice upgrade
OEM Headgasket Honda Acura Integra GSR
OEM Complete Bottom End Gasket Kit Integra
OEM Complete Top End Gasket Kit
ACL Race Bearings
ARP Headstuds No Mains unless u line hone
Wiseco Pistons-RINGS, WRIST PINS, AND LOCKS! <~~~ Aries Pistons would be better
Eagle Rods- Largest ARP Bolts (dont remember size)
LA Sleeves (if you really need to) (stock sleeves can hold like 500+)
OEM CAMS
Supertech Valvesprings & Retainers
Stock valves will hold up to 600 easy (save money and get a 3 angle valve job)
Unless your making mad power save the money on cam gears
Skunk2 Pro Series Intake Manifold yes
New OEM Or Supertech valve seals
Rc or Precision 1000cc injectors
Tial Wastegate
Tial BOV
Hondata S300
Prologger Wideband with boost controler
Walbro 255
This will be good enuff for any street car and part time drag car...
What I changed will save you some cash and be all around stronger
Old Jul 31, 2011 | 04:19 PM
SloHa+ch's Avatar
thanks. i got hks bov and tial wg im hoping for 450-500 after build
Old Jul 31, 2011 | 04:58 PM
no problem, What are your goals with this car?
bambbrose
Dec 3, 2018 10:42 AM
WhiteTrashedDA9
Feb 23, 2014 10:43 PM
DA_JDM
Mar 9, 2007 10:03 AM
mikebaglini
Nov 10, 2004 05:23 AM
K-Drum
Jul 13, 2004 02:58 PM
