building engine for turbo.
Old Apr 23, 2002 | 10:21 AM
Dorikamu's Avatar
Default building engine for turbo.
I am looking to get 230whp from a b18b after turbo.
my motor has bout 100k, so I guess I should rebuild it or something after boosting it. I am not quite familiar with rebuilding the motor.
What are the parts and procedures I should do with the motor b4 boosting it, so that it will be reliable for 230whp (I am guessing that about 18psi?) BTW, I am on a budget... so whatever is REQUIRED to be safe.... I have to do... or I better do
any suggestions/opinions will be helpful...
I didnt find much about the details in rebuilding the engine with the search...
thanks!!
[Modified by chusai, 2:22 PM 4/23/2002]
Old Apr 23, 2002 | 10:38 AM
newsense's Avatar
New User
Default Re: building engine for turbo. (chusai)
You should be able to reliably pull 230whp on 9-10 psi on the stock motor.
Old Apr 23, 2002 | 10:47 AM
Dorikamu's Avatar
Default Re: building engine for turbo. (newsense)
given the motor is 100k miles.. I dont wanna risk anything, what should I do to make the motor more reliable then?
Old Apr 23, 2002 | 12:05 PM
Honda Hick's Avatar
You don't need 18 psi to be running 230 whp. 100k isnt that bad if you havent beaten your motor. I would use the money that you'd use to rebuild your motor and put that towards a Hondata. If you get it well tuned I dont see why it wouldn't be reliable.
Old Apr 23, 2002 | 12:13 PM
PrecisionH23a's Avatar
Default Re: building engine for turbo. (Honda Hick)
i agree. as long as your car runs fine now and doenst have a lot of problems, you should boost 7-8psi safely on your motor. i would advise purchasing a boost controller also for this set up. if you want to fork out a few extra bucks and be safe as well as have a little more power, pistons and rods are always a nice upgrade. with these as well as larger injectors, boost controller, s-afc, or hondata (your choice), you can run 10psi safely but i wouldnt run any more then 12psi on stock sleeves.
Old Apr 23, 2002 | 12:36 PM
Dorikamu's Avatar
Default Re: building engine for turbo. (GudeH23a)
thanks for the info guys..
one last thing, what does the sleeves do? and how do it help the boosting...
why sleeving makes boosting safer?
thanks, you guys are great help.
Old Apr 23, 2002 | 12:39 PM
newsense's Avatar
New User
Re-sleeving with iron sleeves means replacing the cylinder walls with solid iron. Basically means your sleeves will never cracked if tuned properly. Its how the pros are able to run boost levels in excess of 30+psi.....
Old Apr 23, 2002 | 12:43 PM
re-sleeving makes your block virtually bullet proof. youll blow your head off before you crack a sleeve
Old Apr 23, 2002 | 04:27 PM
Dorikamu's Avatar
thanks guys...
I guess I dont really have to resleeve for around 10-12psi....
Old Apr 23, 2002 | 04:37 PM
AlphaKennyWun's Avatar
For what you described, just change the pistons in the car with new rings. Get a blockguard and a pretty good fuel management like hondata w/ injectors.
Old Apr 23, 2002 | 04:56 PM
Dorikamu's Avatar
Default Re: building engine for turbo. (SO3Burner)
what is blockguard? is it the same as sleeves?
Old Apr 23, 2002 | 04:58 PM
SIK IN DA HED's Avatar
New User
replace the pistons, rods, and rings... those always seem to fail the most.
Old Apr 23, 2002 | 05:45 PM
Honda Hick's Avatar
no a blockguard goes between the inner and outer casting of the block. this makes the top of the deck a closed deck so it stronger.
Old Apr 23, 2002 | 10:21 PM
Flamenco-T's Avatar
you can also buy an LS longblock, head and block with internals for around 500ish..
boost the hell out of your motor for now...get standalone...
honda's block are stronger that most of you think...the biggest weakest link out of honda turbo is the ECU, get hondata, boost happy, if you blow it, do a swap....simple..
Old Apr 23, 2002 | 10:22 PM
Flamenco-T's Avatar
Default Re: building engine for turbo. (Flamenco-T)
ooh BTW, you can get 230ish from 8-10 psi...
Old Apr 24, 2002 | 04:44 AM
Dorikamu's Avatar
the problem is... blowing the engine is not something I wanna see...
Old Apr 24, 2002 | 06:54 AM
int3gra's Avatar
when u put in the blockguard, dont u have to machine something?
Old Apr 24, 2002 | 07:38 AM
digitalhav0c's Avatar
Default Re: building engine for turbo. (dlplayboy)
how much boost can the stock b18a1 rods take if they are shot peened and polished. could i run those rod's and aftermarket piston's like JE and run about 12-13 psi safely if i run like a hondata and injector's and maybe msd?
Old Apr 24, 2002 | 08:01 AM
Etylorcen's Avatar
Where can u get a ls longblock that cheap?
Old Apr 24, 2002 | 08:26 AM
Flamenco-T's Avatar
Default Re: building engine for turbo. (Etylorcen)
hmm, partstrader...I founded 3 they range from 400-600 depending on the year..
the 400 ones is a 94 with 85k miles..complete
Old Apr 24, 2002 | 08:45 AM
Dorikamu's Avatar
watch out for partstrader... I have seen to many scammer from there... make sure you get all info before you buy...
Old Apr 24, 2002 | 09:59 AM
ExospeedAMcrx's Avatar
For 10-12 psi, you should be fine with upgraded rods and pistons. The other major upgrade when boostting at that level is to upgrade the injectors to a 310cc.
Check out the block page on the webstore http://www.exospeed.com
Theres different stages of blocks that are available for your build up.
Wil
Old Apr 24, 2002 | 10:16 AM
Cone's Avatar
Default Re: building engine for turbo. (exospeedAMcrx)
I talked to a shop owner about boosting my GS-R. He said block guards aren't needed, and actually hamper the water flow too much, and thus your engine runs hotter because of the lack of water flow, even with the so called "high water flow" ones. He builds plenty of high hp B18's and B16's with just sleves.
-Andrew
EDIT: There are some block guards out their that advertise the ability to just tap it in w/ out machining, but I don't know if I'd trust those or not.
[Modified by Stealth 95 GS-R, 2:17 PM 4/24/2002]
steede
Aug 20, 2009 11:52 AM
1.8t
Apr 6, 2007 10:27 AM
ThaCivicAssassin
26
May 17, 2005 05:34 PM
C_H_A_D
Jan 31, 2005 03:41 PM
CivicHb04
Nov 17, 2002 10:19 PM
