Building a D16 for nitrous. Weakest link?
Old Aug 15, 2006 | 09:30 PM
Tippyman's Avatar
Default Building a D16 for nitrous. Weakest link?
I am getting ready to start building an SOHC ZC (basically just a D16A6) for a 75 shot of nitrous.
I already got a new clutch and flywheel, and an Si tranny ready to go in, so now the motor needs attention.
My plans were: retard timing 2 deg., one step colder plugs, and run race gas when spraying. (Track only spraying, btw.)
I guess the question is, is there any real "weak link" I should worry about before spraying? Pistons? Rods? Rings? Fuel Pump? (I'm running a wet kit, will the FP be an issue?) Say something were to go wrong, what's the first thing that would fail? If I know that now, I can replace it before anything happens, as a security measure .
Old Aug 15, 2006 | 09:35 PM
AaronJ's Avatar
Default Re: Building a D16 for nitrous. Weakest link? (Tippyman)
A good thing to get would be a walbro, either a 190 or a 255, its really up to you. Its obviously going to be pushing the limits of your stock block, but you should be fine. Keep that bottle hot or you won't be happy with nitrous.
Have fun with it, i know i did with mine
Old Aug 16, 2006 | 01:38 AM
Speed Infliction's Avatar
weakest link is the piston rings no question. that is the whole reason i am rebuilding and going ahead and getting a turbo setup.
Old Aug 16, 2006 | 05:16 AM
Tippyman's Avatar
Default Re: Building a D16 for nitrous. Weakest link? (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">weakest link is the piston rings no question. that is the whole reason i am rebuilding and going ahead and getting a turbo setup. </TD></TR></TABLE>
So do they make "upgraded" rings?
Old Aug 16, 2006 | 05:42 AM
gt25CIVICex's Avatar
it's actualy not the rings that are weak its the ring lands (forged pistons will solve that), and the stock block should have no problem with a 75 shot. (properly tuned of course)
Modified by gt25CIVICex at 11:31 AM 8/16/2006
Old Aug 16, 2006 | 10:23 AM
Default Re: Building a D16 for nitrous. Weakest link? (gt25CIVICex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt25CIVICex &raquo;</TD></TR><TR><TD CLASS="quote">it's actualy not the rings that are weak its the ring lands (forged pistons will solve that), and the stock block should have no problem with a 75 shot. (properly tuned of course)
Modified by gt25CIVICex at 11:31 AM 8/16/2006</TD></TR></TABLE>
one day when the bottle is not warm enough and you spray...there goes the rings. it happend to me sad to say.
Old Aug 16, 2006 | 11:12 AM
quicksilver1689's Avatar
i ♥ snails
Go with rods and pistons up your spray too 100-125 shot and enjoy
Old Aug 16, 2006 | 11:52 AM
slowturbocx's Avatar
Default Re: (quicksilver1689)
i would say the rods and the rings/ringlands woudl have to be the weak links
good luck on your car
Old Aug 16, 2006 | 12:33 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">one day when the bottle is not warm enough and you spray...there goes the rings. it happend to me sad to say.</TD></TR></TABLE>
Why would bottle temp cause it to run lean?
Old Aug 16, 2006 | 01:11 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Why would bottle temp cause it to run lean?</TD></TR></TABLE>
if the bottle isnt warm enough it sprays less than your jetted for so i dont know what he is talking about..
Old Aug 16, 2006 | 01:14 PM
Tippyman's Avatar
That's what I'm thinking. It would just make me run richer, which is actually safer.
Old Aug 16, 2006 | 01:35 PM
Tippyman's Avatar
Would a larger fuel pump adversely effect normal, everyday driving?
Tippyman
31
Aug 19, 2006 12:10 AM
keepitjdm
Dec 9, 2004 06:44 AM
speedehatch
May 4, 2004 07:12 AM
BseriesHatch
May 27, 2003 10:35 AM
3gLudeH22A
Jan 2, 2002 06:07 PM
