Building a custom 3" system
Old Aug 14, 2002 | 03:23 AM
hardcorehonda's Avatar
Default Building a custom 3" system
I'm planning to build a custom 3" ex sys for my d16 greddy coupe...
I'm wondering.. should i use a resonator/damper .. or just straitpipe to the rear and then the "muffler"?
HKS, Greddy, thermal al use resonators + damper
(sorry i can't find the correct words....i'm from europe)
[Modified by hardcorehonda, 12:24 PM 8/14/2002]
Old Aug 14, 2002 | 03:37 AM
rjardy's Avatar
Default Re: Building a custom 3" system (hardcorehonda)
i would use a resonator, what exactly are you looking for out of your setup?
Rob
Old Aug 14, 2002 | 05:07 AM
Default Re: Building a custom 3" system (rjardy)
i just want low spool times... and a good flowing system...
sound doesn't bother me..
the downpipe wil also be replaced by a 3" dp
Old Aug 14, 2002 | 07:12 AM
Smashback's Avatar
It won't if you have A/C
When I get my new manifold though I'm going to work on putting together a downpipe that starts at 2.5" and expands to 3" before it turns under the oil pan.
Mine is pretty "droning" sometimes, i have a 2.5 DP, 3" Carsound cat, 3" piping back to a 3" Magnaflow. Sounds REAL good, but pretty noisy. Thinking about putting a resonator on there.
Old Aug 14, 2002 | 09:23 AM
b18b98's Avatar
Default Re: Building a custom 3" system (mplex2000)
will a 3" cat flow better then a 2.5" testpipe?
Old Aug 14, 2002 | 12:37 PM
Default Re: Building a custom 3" system (b18b98)
i have no AC ... wuahahahaah
Old Aug 14, 2002 | 01:10 PM
TurBoTeG's Avatar
"HKS, Greddy, thermal al use resonators + damper "
hmm thats funny...my 3' thermal didnt come w/ a resonator....but my 2.25 did
[Modified by TurBoTeG, 10:11 PM 8/14/2002]
Old Aug 14, 2002 | 02:31 PM
morepoop4u's Avatar
Slow_ass_4dr is having a gb on the 3" piping and resonators in this forum.
Old Aug 14, 2002 | 06:38 PM
Smashback's Avatar
I doubt it. Look inside a cat sometime
Thing is there is usually a VERY small difference on Hondas between test pipes and high flow cats...at least from the results I've read. Not worth it to me to use a test pipe on my daily driver.
[Modified by mplex2000, 3:39 AM 8/15/2002]
Old Aug 14, 2002 | 07:30 PM
The Mick's Avatar
https://honda-tech.com/zerothread?id=245836
BTW, as someone stated above, a 3" Thermal exhaust doesn't come with a resonator.
Old Aug 14, 2002 | 07:48 PM
TurBoTeG's Avatar
Default Re: Building a custom 3" system (The Mick)
[Modified by TurBoTeG, 4:51 AM 8/15/2002]
BLK99VTECR
12
Jan 17, 2005 08:23 AM
NirVTEC
Sep 17, 2003 12:02 PM
FredoSP
Feb 23, 2003 08:55 PM
98civicEX
Mar 27, 2002 10:23 PM
